Our docs have moved to a new home!
Please update your bookmarks, and contact us if you have any questions.
How to secure an Ingress with TLS.
Requirements
You will need:
A laptop or desktop running Ubuntu (or you can use a VM).
Juju and MicroK8s installed. We’ll also want to make sure the ingress add-on is enabled, which we can do by running
microk8s enable ingress. -
Charmcraft installed.
A working
nginx-ingress-integratordeployment. -
OpenSSL installed.
Creating the TLS secret
For the sake of simplicity you’ll create a self-signed SSL certificate for the tutorial, but feel free to add SSL
certificates of other types.
For the creation of the Certificate Authority key execute:
openSSL genrsa -out ca.key 2048
And for the creation of the certificate itself:
openssl req -x509 -new -nodes -days 365 -key ca.key -out ca.crt -subj "/CN=exampledomain.com"
With the CA key and cert created, create the actual Kubernetes secret with:
microk8s kubectl create secret tls my-tls-secret --key ca.key --cert ca.crt
After the secret creation you can check the secret by running:
microk8s kubectl get secrets/my-tls-secret
microk8s kubectl describe secrets/my-tls-secret
At last, relate the nginx-ingress-integrator charm with the MicroK8s TLS secret by setting the config option:
juju config nginx-ingress-integrator tls-secret-name="my-tls-secret"
Now your NGINX Ingress integrator is secured with TLS.
