Hi, here is juju team Pulse report.
Task
- DOCAPOST outage Bootstack support
- Helped improve How to install Charmed Kubeflow
- Helped improve Deploying Kubeflow Pipelines with Azure AKS spot instances
- Upgrade Juju version for terraform provider
- Help improve part 1 of Get started with Charmed Kubeflow
- Helped improve How to integrate Charmed Kubeflow with Charmed MLflow
- Collect API interaction tips
- Help clean up https://discourse.charmhub.io/t/how-to-access-the-kubeflow-dashboard/3883
- Help clean up The `kubeflow` bundle
- Help clean up How to install Charmed Kubeflow on AWS with CloudFormation
- Help clean up How to prepare to install Charmed Kubeflow on MicroK8s behind a web proxy
- Modify azure clean-up job
- File notify watcher
- Terraform support users access
- Generate one markdown file per command
- Add PR template
- Create new storage http server
- Review How to configure machine image metadata for your OpenStack cloud
- Terraform support managing users
- Terraform Credential management
- Put down first draft of spec for new charm documentation standard, with actionable items
- Figure out how info gets into Charmhub
- Review How to write a topic page
- Review Deploy the COS Lite observability stack on MicroK8s
- Review https://discourse.charmhub.io/t/document-your-library/4422
- Review How to write a tutorial
- Review How to add docs to your charm page on Charmhub
- Review https://discourse.charmhub.io/t/your-first-kubernetes-operator/3246
- Review https://discourse.charmhub.io/t/how-to-work-with-bundles-in-charmcraft/4246
- Review https://discourse.charmhub.io/t/how-to-work-with-resources-in-charmcraft/4283
- Review https://discourse.charmhub.io/t/publish-your-operator-in-charmhub/3386
- Review https://discourse.charmhub.io/t/how-to-set-up-remote-elasticsearch-monitoring-of-an-elasticsearch-cluster/2864
- Review How to deploy StorageOS on Charmed Kubernetes
- Review https://discourse.charmhub.io/t/how-to-install-kubeapps-on-your-kubernetes-cluster/2646
- Review https://discourse.charmhub.io/t/how-to-get-started-with-hadoop-spark/2645
- Review https://discourse.charmhub.io/t/how-to-ensure-security-and-isolation-in-charmed-kubernetes-with-kata-containers/2644
- Review https://discourse.charmhub.io/t/how-to-stream-data-analytics-with-apache-hadoop/2643
- Review How to use GitLab as a container registry for Kubernetes
- Review https://discourse.charmhub.io/t/how-to-get-started-with-charmed-kubernetes/2641
- Review https://discourse.charmhub.io/t/how-to-deploy-and-configure-a-multi-node-rabbitmq-cluster-on-ubuntu-server/3116
- Review How to deploy, install and manage a high-availability PostgreSQL cluster on Ubuntu Server
- Review Building and deploying a mini charm
- Set up redirects from juju.is/tutorials to the version in the OLM / SDK juju.is/docs
- Fix issue with non-fixed headers.
- Create first version of spec with initial description
- Describe Subordinate-like approach for deploying app on DPU
- Add overlay example and description into Bundle Section
- Setup DeployFromRepository outline method
- Fix refresh integration tests broken by bug fix.
- Rewrite
apiserver/facades/client/keymanagerto not useJujuConnSuite - Terraform manages ssh keys
- security awareness training
- Implement changestream on top of dqlite.
- Restructure OLM How to manage applications
- Develop the bash-based version of nw-deploy-bionic-aks test
- move tests to appropriate locations: api/client/client gomock unit tests
Bug
- Container NICs without addresses
- Ensure juju can refresh and update a repository resource with no new charm revision available.
