Overview
Duration 0:10
In this tutorial you will create a Kubernetes operator in Python, and deploy it. We use the Python Operator Framework and the Juju operator lifecycle manager.
Create the charm
Duration 05:00
Install charmcraft with sudo snap install charmcraft
charmcraft init
Make a clean directory for your operator (mkdir my-charm
) and use charmcraft init
in that directory to setup the base file structure of a charm:
$ mkdir hello-world
$ cd hello-world
$ charmcraft init
All done.
There are some notes about things we think you should do.
These are marked with ‘TODO:’, as is customary. Namely:
README.md: fill out the description
README.md: explain how to use the charm
metadata.yaml: fill out the charm's description
metadata.yaml: fill out the charm's summary
Now you’ll have a file tree that includes all the key elements of your charmed operator:
$ tree
├── actions.yaml
├── config.yaml
├── LICENSE
├── metadata.yaml
├── README.md
├── requirements-dev.txt
├── requirements.txt
├── run_tests
├── src
│ └── charm.py
└── tests
├── __init__.py
└── test_charm.py
2 directories, 11 files
That is a minimal charmed operator! It has code we can extend, with tests, a requirements files for our Python dependencies, some YAML files that describe the charm (metadata.yaml
for a name and description as well as key behavioural infromation, actions.yaml
for day-2 operations like backup and restore that you want to offer, config.yaml
for, unsurprisingly, any configuration options you want to offer on your operator) and other project files like README, LICENSE, etc.
The only things you really need to get right are src/charm.py
which is the operator code, and metadata.yaml
which defines the behaviour of the operator on K8s.
This baby operator won’t do anything special, just log that it was installed properly.
The operator code in Python
#!/usr/bin/env python3
import logging
from ops.charm import CharmBase
from ops.main import main
logger = logging.getLogger(__name__)
class MyCharm(CharmBase):
def __init__(self, *args):
super().__init__(*args)
self.framework.observe(self.on.install, self.on_install)
def on_install(self, event):
logger.info("Congratulations, the charm was properly installed!")
if __name__ == "__main__":
main(MyCharm)
A charmed operator is pure Python.
We have a couple imports .logging
is from Python’s stdlib, and ops
is the Python Operator Framework.
The charm itself is a straightforward Python class which inherits from CharmBase
and which we pass to the framework’s main
. This is all we need to start using the Operator Framework.
A charm class is a collection of event handling methods. The Operator Framework delivers events to your charm for things like install, remove, upgrade, configure, actions like backup/restore, and integration with other operators. Any events you want to handle become methods on the class.
In the minimal charm class, after calling the parent class __init__
, we tell the framework to call our on_install
method when the install
event is triggered. That method only logs that all succeeded.
Metadata to define behaviour
You don’t deploy your operator directly. Instead, you ask the operator lifecycle manager to deploy it. The metadata.yaml
file tells the OLM about the operator, so that it can launch it correctly and manage it successfully.
Let’s edit that file and make it our own:
summary: My first operator from the tutorial
description: |
A very simple charm to demonstrate charmcraft and the
Python operator framework.
series: [kubernetes]
The series
element in that metadata.yaml
is a list of platforms that the operator will work on. In this case, the operator works on Kubernetes. You can also make operators for traditional applications on Linux or Windows, but we won’t go into the detail of that here.
Python dependencies
You may have spotted the requirements.txt
file in that tree. It’s where we declare any Python dependencies. For this tutorial only need the Operator Framework which is ops
and it should be there already thanks to charmcraft init
$ cat requirements.txt
ops
You can of course add other PyPI packages which charmcraft will fetch and keep up to date for you as part of the build process.
Build the charm
Duration 02:00
Your operator is pure code. To share it with someone else, it helps to have a package for it, which we call a charm. A charm of an operator is like a deb of a binary: a package that can be shared, published and retrieved.
Let’s build our charm:
$ charmcraft build
Done, charm left in 'hello-world.charm'
A charm is really just a zip file of the code and all its dependencies, as well as the metadata. charmcraft build
just fetches the dependencies, compiles any modules, makes sure you have all the right pieces of metadata, and zips it up for easy distribution.
Take a look inside. You’ll recognise your files, and then a virtualenv with the Python dependencies clearly mapped out:
$ unzip -l hello-world.charm
Archive: hello-world.charm
Length Date Time Name
4 2020-11-12 20:48 requirements.txt
429 2020-11-12 20:48 actions.yaml
379 2020-11-12 20:48 README.md
302 2020-11-12 20:48 run_tests
35147 2020-11-12 20:48 LICENSE
93 2020-11-12 22:06 dispatch
222 2020-11-12 20:48 metadata.yaml
305 2020-11-12 20:48 config.yaml
27 2020-11-12 20:48 requirements-dev.txt
99 2020-11-12 20:48 .flake8
93 2020-11-12 22:06 hooks/install
93 2020-11-12 22:06 hooks/upgrade-charm
93 2020-11-12 22:06 hooks/start
1112 2020-11-12 20:48 src/charm.py
1170 2020-11-12 20:48 tests/test_charm.py
0 2020-11-12 20:48 tests/__init__.py
92 2020-11-12 22:06 venv/ops-1.0.1.dist-info/WHEEL
4 2020-11-12 22:06 venv/ops-1.0.1.dist-info/top_level.txt
11358 2020-11-12 22:06 venv/ops-1.0.1.dist-info/LICENSE.txt
1718 2020-11-12 22:06 venv/ops-1.0.1.dist-info/RECORD
4 2020-11-12 22:06 venv/ops-1.0.1.dist-info/INSTALLER
5531 2020-11-12 22:06 venv/ops-1.0.1.dist-info/METADATA
103 2020-11-12 22:06 venv/PyYAML-5.3.1.dist-info/WHEEL
1101 2020-11-12 22:06 venv/PyYAML-5.3.1.dist-info/LICENSE
11 2020-11-12 22:06 venv/PyYAML-5.3.1.dist-info/top_level.txt
2456 2020-11-12 22:06 venv/PyYAML-5.3.1.dist-info/RECORD
4 2020-11-12 22:06 venv/PyYAML-5.3.1.dist-info/INSTALLER
1758 2020-11-12 22:06 venv/PyYAML-5.3.1.dist-info/METADATA
14192 2020-11-12 22:06 venv/ops/storage.py
819 2020-11-12 22:06 venv/ops/__init__.py
46 2020-11-12 22:06 venv/ops/version.py
32748 2020-11-12 22:06 venv/ops/charm.py
4139 2020-11-12 22:06 venv/ops/jujuversion.py
34898 2020-11-12 22:06 venv/ops/testing.py
41255 2020-11-12 22:06 venv/ops/framework.py
2155 2020-11-12 22:06 venv/ops/log.py
47924 2020-11-12 22:06 venv/ops/model.py
15459 2020-11-12 22:06 venv/ops/main.py
34825 2020-11-12 22:06 venv/ops/__pycache__/charm.cpython-38.pyc
2129 2020-11-12 22:06 venv/ops/__pycache__/log.cpython-38.pyc
184 2020-11-12 22:06 venv/ops/__pycache__/version.cpython-38.pyc
35527 2020-11-12 22:06 venv/ops/__pycache__/framework.cpython-38.pyc
281 2020-11-12 22:06 venv/ops/__pycache__/__init__.cpython-38.pyc
47958 2020-11-12 22:06 venv/ops/__pycache__/model.cpython-38.pyc
11195 2020-11-12 22:06 venv/ops/__pycache__/main.cpython-38.pyc
3539 2020-11-12 22:06 venv/ops/__pycache__/jujuversion.cpython-38.pyc
12911 2020-11-12 22:06 venv/ops/__pycache__/storage.cpython-38.pyc
28496 2020-11-12 22:06 venv/ops/__pycache__/testing.cpython-38.pyc
9213 2020-11-12 22:06 venv/ops/lib/__init__.py
7616 2020-11-12 22:06 venv/ops/lib/__pycache__/__init__.cpython-38.pyc
25495 2020-11-12 22:06 venv/yaml/parser.py
2533 2020-11-12 22:06 venv/yaml/error.py
2837 2020-11-12 22:06 venv/yaml/dumper.py
4883 2020-11-12 22:06 venv/yaml/composer.py
2445 2020-11-12 22:06 venv/yaml/events.py
4165 2020-11-12 22:06 venv/yaml/serializer.py
2061 2020-11-12 22:06 venv/yaml/loader.py
13170 2020-11-12 22:06 venv/yaml/__init__.py
2573 2020-11-12 22:06 venv/yaml/tokens.py
14184 2020-11-12 22:06 venv/yaml/representer.py
43006 2020-11-12 22:06 venv/yaml/emitter.py
51277 2020-11-12 22:06 venv/yaml/scanner.py
1440 2020-11-12 22:06 venv/yaml/nodes.py
3846 2020-11-12 22:06 venv/yaml/cyaml.py
8970 2020-11-12 22:06 venv/yaml/resolver.py
6794 2020-11-12 22:06 venv/yaml/reader.py
28627 2020-11-12 22:06 venv/yaml/constructor.py
10104 2020-11-12 22:06 venv/yaml/__pycache__/representer.cpython-38.pyc
2335 2020-11-12 22:06 venv/yaml/__pycache__/error.cpython-38.pyc
11959 2020-11-12 22:06 venv/yaml/__pycache__/parser.cpython-38.pyc
20857 2020-11-12 22:06 venv/yaml/__pycache__/constructor.cpython-38.pyc
1760 2020-11-12 22:06 venv/yaml/__pycache__/nodes.cpython-38.pyc
1858 2020-11-12 22:06 venv/yaml/__pycache__/dumper.cpython-38.pyc
4572 2020-11-12 22:06 venv/yaml/__pycache__/reader.cpython-38.pyc
25388 2020-11-12 22:06 venv/yaml/__pycache__/emitter.cpython-38.pyc
5513 2020-11-12 22:06 venv/yaml/__pycache__/resolver.cpython-38.pyc
11880 2020-11-12 22:06 venv/yaml/__pycache__/__init__.cpython-38.pyc
4009 2020-11-12 22:06 venv/yaml/__pycache__/events.cpython-38.pyc
3598 2020-11-12 22:06 venv/yaml/__pycache__/composer.cpython-38.pyc
3355 2020-11-12 22:06 venv/yaml/__pycache__/serializer.cpython-38.pyc
4970 2020-11-12 22:06 venv/yaml/__pycache__/tokens.cpython-38.pyc
3441 2020-11-12 22:06 venv/yaml/__pycache__/cyaml.cpython-38.pyc
2199 2020-11-12 22:06 venv/yaml/__pycache__/loader.cpython-38.pyc
25304 2020-11-12 22:06 venv/yaml/__pycache__/scanner.cpython-38.pyc
812625 84 files
Deploy the charm
Duration 02:00
You will first deploy the operator lifecycle manager. If you already have Juju running on a K8s cluster, you can skip ahead to Make a new model
below.
Get access to a Kubernetes cluster
There are sooooo many ways to get a Kubernetes that we are not going to list them here. For a local K8s on your workstation we recommend MicroK8s. But really it shouldn’t matter.
You know you are good to go when you can type:
kubectl config get-clusters
NAME
You should see a cluster, or list of clusters, under NAME.
Launch the Juju OLM
You’ll need the operator lifecycle manager running on your K8s cluster.
$ sudo snap install juju --classic
$ juju add-k8s mycluster --cluster-name=my_cluster_name
Now you should have your cluster in the output of juju list-clouds
XXX example output here.
Start the operator lifecycle manager on your K8s cluster:
$ juju bootstrap mycluster
You should now have a namespace on K8s for this OLM controller:
kubectl get namespaces
NAME STATUS AGE
kube-system Active 10d
kube-public Active 10d
kube-node-lease Active 10d
default Active 10d
controller-XYZ Active 2m
Make a new model
Operators are deployed in groups, called models. Think of a model as a canvas where you can paint the software you want to deploy and integrate. Let’s add a new model:
Added 'hello-world' model on <XYZ> with credential 'XXX' for user 'XXX'
On Kubernetes, each model is put into a different namespace on the K8s. So you should see a hello-world
namespace in your Kubernetes:
NAME STATUS AGE
default Active 10d
controller-XYZ Active 5m
hello-world Active 79s
And of course the new model in Juju:
$ juju models
Controller: XXX
Model Cloud/Region Type Status Units Access Last connection
controller XXX kubernetes available - admin just now
hello-world* XXX kubernetes available - admin never connected
And deploy your operator!
Switch to a different terminal and execute the following to see the logging:
$ juju debug-log
controller-0: 22:37:02 INFO juju.worker.apicaller [48d45f] "controller-0" successfully connected to "localhost:17070"
controller-0: 22:37:02 INFO juju.worker.logforwarder config change - log forwarding not enabled
controller-0: 22:37:02 INFO juju.worker.logger logger worker started
controller-0: 22:37:02 INFO juju.worker.pruner.statushistory status history config: max age: 336h0m0s, max collection size 5120M for hello-world (48d45fd3-bc24-467e-8f88-2378dda24211)
controller-0: 22:37:02 INFO juju.worker.pruner.action status history config: max age: 336h0m0s, max collection size 5120M for hello-world (48d45fd3-bc24-467e-8f88-2378dda24211)
Switch back to the original terminal, and let’s deploy our charm:
juju deploy ./hello-world.charm
You can watch the evolving status of the deployment with:
$ watch -n 1 juju status --color
Wait some moments to let the Juju OLM do its magic, and at some point, in the juju debug-log
terminal, a line very similar to the following one will appear:
unit-hello-world-1: 13:26:10 INFO unit.hello-world/1.juju-log Congratulations, the charm was properly installed!
So, you have successfully created a minimal charmed operator, packaged it as a charm, deployed the operator lifecycle manager (OLM), and asked it to create a new model on the K8s, then asked the OLM to deploy your operator into that model.
To tear this all down:
$ juju destroy-model hello-world
You should now see only a controller model in your set of juju models:
$ juju models
Controller: XYZ
controller cluster kubernetes available - admin just now
Note the controller name at the top of that listing. Now you can tear down that OLM as well, with:
$ juju destroy-controller XYZ
That’s all!
