| Key | Value |
| Summary | Learn how to deploy StorageOS on Charmed Kubernetes |
| Categories | deploy-applications |
| Difficulty | 3 |
| Author | Peter De Sousa peter.de.sousa@canonical.com |
Overview
Duration: 5:00
Kubernetes offers a range of storage solutions out of the box, but the majority of these are specific to cloud providers, for example, AWS or Google Cloud. This means that the options left for bare metal deployments are Ceph, NFS or local.
StorageOS is a newcomer to this area providing an easy to setup solution for storage in Charmed Kubernetes which is up and running within minutes.
In this tutorial you’ll learn how to…
- Deploy the StorageOS operator
- Create a secret for StorageOS
- Create a workload on top of StorageOS
You will only need
- a Charmed Kubernetes cluster
ⓘ If you do not have a Charmed Kubernetes cluster, you can refer to the following tutorial to spin up one in minutes. Charmed Kubernetes is a production-grade Kubernetes offering from Canonical which is fully compliant with the upstream project. Get Charmed Kubernetes right away and benefit from simplified deployments and operations provided by Juju charms.
Cluster preparation
Duration: 2:00
Make sure that your Kubernetes Control Plane is configured to allow kubeapi-server to run in privileged mode.
juju config kubernetes-control-plane allow-privileged=true
Setting up StorageOS
Duration: 5:00
Getting started
To get StorageOS up and running follow these three easy steps:
- Install the StorageOS operator
- Create a secret
- Deploy the daemonsets
To get started with our deployment of StorageOS we need to first deploy the StorageOS operator:
kubectl create -f https://github.com/storageos/cluster-operator/releases/download/1.4.0/storageos-operator.yaml
This operator YAML also creates a new Kubernetes storage class ‘fast’ which will be important later.
Create an initial StorageOS user account
When deploying Storage OS the deployment will create a user and password using the secret defined below. This is important if you wish to use the StorageOS CLI later:
kubectl create -f - <<END
apiVersion: v1
kind: Secret
metadata:
namespace: "storageos-operator"
labels:
app: "storageos"
type: "kubernetes.io/storageos"
data:
apiUsername: dWJ1bnR1
apiPassword: dWJ1bnR1
# echo ‘ubuntu’ | base64
END
Now that you have the StorageOS initial account configured you can go ahead and deploy the StorageOS daemon sets. This step is important and if not configured properly you may get an error similar to this:
storageos-daemonset-qpwfn 0/1 Init:Error 11 14m
Deploy the StorageOS cluster
Duration: 10:00
The following yaml will deploy a StorageOS cluster of three daemon sets:
apiVersion: "storageos.com/v1"
kind: StorageOSCluster
metadata:
spec:
secretRefName: "storageos-api" # Reference the Secret created in the previous step
secretRefNamespace: "storageos-operator" # Namespace of the Secret
k8sDistro: "kubernetes"
images:
nodeContainer: "storageos/node:1.4.0" # StorageOS version
resources:
requests:
memory: "512Mi"
END
You can check the status of the deployment by watching the daemonset pods:
kubectl -n storageos get pods -w
Deploying a workload on StorageOS
Duration: 10:00
Now to try out your new StorageOS solution you can use a customised version of MySQL Wordpress Deployment from the Kubernetes docs.
Run each of these commands to create a kustomization.yaml, mysql-deployment.yaml and wordpress-deployment.yaml.
Kustomization.yaml
Create a file with the following content:
cat <<END > kustomization.yaml
secretGenerator:
- name: mysql-pass
literals:
- password=ubuntu
resources:
- mysql-deployment.yaml
- wordpress-deployment.yaml
END
Mysql-deployment.yaml
cat <<END > mysql-deployment.yaml
apiVersion: v1
kind: Service
metadata:
labels:
app: wordpress
spec:
ports:
- port: 3306
selector:
app: wordpress
tier: mysql
clusterIP: None
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
annotations:
volume.beta.kubernetes.io/storage-class: fast
labels:
app: wordpress
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 20Gi
apiVersion: apps/v1 # for versions before 1.9.0 use apps/v1beta2
kind: Deployment
metadata:
labels:
app: wordpress
spec:
selector:
matchLabels:
app: wordpress
tier: mysql
strategy:
type: Recreate
template:
metadata:
labels:
app: wordpress
tier: mysql
spec:
containers:
- image: mysql:5.6
env:
- name: MYSQL_ROOT_PASSWORD
valueFrom:
secretKeyRef:
key: password
ports:
- containerPort: 3306
volumeMounts:
- name: mysql-persistent-storage
mountPath: /var/lib/mysql
volumes:
persistentVolumeClaim:
claimName: mysql-pv-claim
END
Wordpress-deployment.yaml
cat <<END > wordpress-deployment.yaml
apiVersion: v1
kind: Service
metadata:
labels:
app: wordpress
spec:
ports:
- port: 80
selector:
app: wordpress
tier: frontend
type: NodePort
apiVersion: v1
metadata:
labels:
app: wordpress
annotations:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 20Gi
kind: Deployment
metadata:
labels:
app: wordpress
spec:
selector:
matchLabels:
app: wordpress
tier: frontend
strategy:
type: Recreate
template:
metadata:
labels:
app: wordpress
tier: frontend
spec:
containers:
- image: wordpress:4.8-apache
env:
- name: WORDPRESS_DB_HOST
value: wordpress-mysql
- name: WORDPRESS_DB_PASSWORD
valueFrom:
secretKeyRef:
key: password
ports:
- containerPort: 80
volumeMounts:
- name: wordpress-persistent-storage
mountPath: /var/www/html
volumes:
claimName: wp-pv-claim
END
The key point of these deployments is the PVC found in both WordPress and MySQL deployments:
apiVersion: v1
metadata:
labels:
app: wordpress
annotations:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 20Gi
This example was taken from the Wordpress deployment, the annotation here has been replaced with StorageOS’s ‘fast’ storage class, this will ask Kubernetes/StorageOS to provision a volume according to the spec.
Once all of the files have been created, run:
kubectl create -k ./
This will deploy all of the secrets and deployments needed for a WordPress site to operate.
Access your new site
Duration: 5:00
Check the service status:
kubectl get pods
You should see something like this:
NAME READY STATUS RESTARTS AGE
csi-rbdplugin-attacher-0 1/1 Running 1 60m
csi-rbdplugin-bxgsk 2/2 Running 1 59m
csi-rbdplugin-kcmdd 2/2 Running 2 35m
csi-rbdplugin-provisioner-0 3/3 Running 0 60m
csi-rbdplugin-zlglm 2/2 Running 1 59m
wordpress-74db446497-2724m 1/1 Running 1 10m
wordpress-mysql-7c795bf6dc-9t7dj 1/1 Running 0 10m
Once the wordpress and mysql pods are running, you can run:
kubectl get svc
This will give you the service address:
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
csi-rbdplugin-attacher ClusterIP 10.152.183.137 <none> 12345/TCP 56m
csi-rbdplugin-provisioner ClusterIP 10.152.183.170 <none> 12345/TCP 55m
kubernetes ClusterIP 10.152.183.1 <none> 443/TCP 61m
wordpress NodePort 10.152.183.16 <none> 80:31625/TCP 6m11s
wordpress-mysql ClusterIP None <none> 3306/TCP 6m12s
Now you can try to access the WordPress site by navigating to:
https://10.152.183.16/
You can go through the WordPress to create an account you should get something like this:
That’s all folks!
Congratulations! In this tutorial, you deployed StorageOS on Charmed Kubernetes and created a WordPress site which used StorageOS as it’s storage backend.
This tutorial can be adapted for other tasks which require persistent volumes and shows you the ease of using a solution such as StorageOS offers.
Where to go from here?
- Explore Charmed Kubernetes
- Use Kubernetes straight away for free with MicroK8s
- Looking for production-grade Kubernetes?
- StorageOS docs
