This is a small release primarily focused around documentation and some minor quality-of-life bug fixes.
New
- The controller name is now rendered in the model lists.
- The machine table in the model details pages now shows the Juju agent status values instead of the provider instance status.
Bug Fixes
- The pinger now stops pinging if the websocket connection is terminated.
- The charts on the controller page now show as disabled if no data is provided.
- When filtering the tables in the model details pages the unit counts no longer incorrectly change.
- When logging out it now shows the log-in UI again.
- Local charm icons are now shown as the default charm icon instead of broken. Weβre working with the Juju team on displaying the correct charm icons and this will be available in a future Juju release.
Maintenance
- Updated Sentry ID to allow for better issue tracking.
Documentation
- Added how to perform a release.
- Added how to write React components.
- Added how to write tests.
- Added instructions on QA.
- Added the Juju commands.
- Added instructions on accessing the Dashboard via nested VMs.
Upcoming
Over the past month weβve been focused on a few things that youβll see in upcoming releases.
- Refactoring of the JavaScript implementation of libjuju by converting it to TypeScript to provide typed param and response values and resolving a number of developer experience issues that weβve found over time. Weβre expecting a release of this update in the next couple weeks.
- Investigations into:
- a combo search and filter UI pattern.
- different model detail page layouts
- a new Machine view and SSH
- Adding the ability to position applications in the Topology to better represent your models. These positions will be persisted and included with bundle exports so future deployments of the bundle will retain the same visualizations.
Upgrade Instructions
