How to create a track for your charm
See also: Channel > Track
This document shows how to create a track for your charm.
Contents:
  1. Request a track guardrail
  2. Create the track
See also: Channel > Track > Guardrail
To request a track guardrail, contact a Charmhub admin by creating a post on Discourse under the charmhub requests category, that is, here: charmhub requests - Charmhub .
Create the track
Once you’ve requested a track guardrail, there are two ways to create a new track for your charm – you can keep contacting a Charmhub admin every time or you can self-service. For most cases the latter option is likely to be more convenient and faster.
Contact a Charmhub admin
To create a new track by contacting a Charmhub admin, create a post on Discourse under the charmhub requests category, that is, here: charmhub requests - Charmhub . The admin will create the new track that fits within the track guardrail you’ve set up for your charm.
Self-service
To create a new track yourself, follow the steps below:
As you might notice, this path is currently a little hacky. In the long-term it should become a lot smoother as there are plans to support it through the Charmcraft CLI.
As you will see, this method currently relies on charmcraft+ curl. We recommend the Charmcraft bit because Charmcraft already understands the authentication mechanism used by Charmhub and can generate a suitable authentication token (macaroon) that will make it possible to then use curl directly to interact with the Charmhub API. This method also has the advantage that it can be adapted to use any HTTP client or library as long as it can pass custom headers.
1. Enable curl access to the Charmhub API.
First, install curl and jq.
You might already have both.
Then, use Charmcraft to log in to Charmhub and export your Charmhub credentials / token (macaroon) to a file:
charmcraft login --export charmhub-creds.dat
Next, decode and extract the macaroon from the .dat file and place it in a header in an environment variable:
export CHARMHUB_MACAROON_HEADER="Authorization: Macaroon $(cat charmhub-creds.dat | base64 -d | jq -r .v)"
At this point you can use this variable in curl commands – just make sure to specify the correct Content-Type.
2. Use curl to view the existing guardrails and tracks. To view the guardrails and tracks associated with your charm, issue an HTTP GET request to /v1/<namespace>/<name>. For example, for a charm named hello-world-charm:
curl https://api.charmhub.io/v1/charm/hello-world-charm -H'Content-type: application/json' -H "$CHARMHUB_MACAROON_HEADER"
The guardrails and tracks of the package will be under the track-guardrails and tracks keys of metadata. Now you know what the new track may look like.
See more: Charmhub API docs > package_metadata
If you want to view the guardrails and tracks for all published charms: Issue an HTTP GET request to /v1/<namespace>, as below:
curl https://api.charmhub.io/v1/charm -H'Content-type: application/json' -H "$CHARMHUB_MACAROON_HEADER"
See more: Charmhub API docs > list_registered_names
3. Use curl to create a new track. Finally, to create a new track for your charm, issue an HTTP POST request to /v1/<namespace>/<name>/tracks, where name and namespace refer to the name and type of the package respectively. For example, given a charm named hello-world-charm, one can create two tracks v.1 and v.2 as follows:
curl https://api.charmhub.io/v1/charm/hello-world-charm/tracks -X POST -H'Content-type: application/json' -H "$CHARMHUB_MACAROON_HEADER" -d '[{"name": "v.1"}, {"name": "v.2"}]'
Of course, the tracks must conform to the existing guardrail for the charm.
See more: Charmhub API docs > create_tracks
That’s it, you now have a new track for your charm!
