Hello, we would like to add an extra channel “legacy” to the landscape-client charm. I was reading these instructions, and it suggests to get a guard rail first How to create a track for your charm
Hi,
Yes, that’s correct. In order to make use of the self-service track creation functionality you need to request a guardrail first. We can do this immediately as soon as you provide us the regex pattern (i.e. guardrail) that’ll govern all your future track creations (including legacy) for landscape-client.
Thanks,
Odysseus
@kevinnasto Looking at https://charmhub.io/landscape-client I don’t know if one of these would help?
Strictly “latest” or “legacy”:
latest|legacy
Allowing “latest”, “legacy”, “N”, “N.N” and “NN.NN”:
latest|legacy|\d{1,2}(?:\.\d{1,2})?
Yes these options work. However, right now the plan is to only add the “legacy” one. Is it alright if the others are not currently activated (maybe later they will)? Or does the regex need to be changed?
We can make adjustments in the future, so if you don’t have specific plans the simplest regex is probably best for now.
Ok then lets just do “legacy” then
Per offline talk, let’s go with your original recommendation
latest|legacy|\d{1,2}\.\d{1,2}
This was done.
