From Zero to Hero: Write your first Kubernetes charm > Expose operational tasks via actions
See previous: Preserve your charm’s data
This document is part of a series, and we recommend you follow it in sequence. However, you can also jump straight in by checking out the code from the previous branches:
git clone https://github.com/beliaev-maksim/k8s-charm-tutorial.git
cd k8s-charm-tutorial
git checkout 05_preserve_charm_data
git checkout -b 06_create_actions
A charm should ideally cover all the complex operational logic within the code, to help avoid the need for manual human intervention.
Unfortunately, that is not always possible. As a charm developer, it is thus useful to know that you can also expose charm operational tasks to the charm user by defining special methods called actions
This can be done by adding actions in a file called actions.yaml
and then adding action event handlers to the src/charm.py
file.
In this part of the tutorial we will follow this process to add an action that will allow a charm user to view the current database access points and, if set, also the username and the password.
Contents:
Define the actions
In the project root folder, create a file called actions.yaml
Open the file and add to it a block defining an action, as below. As you can see, the action is called get-db-info
and it is intended to help the user access database authentication information. The action has a single parameter, show-password
; if set to True
, it will show the username and the password.
get-db-info:
description: Fetches Database authentication information
params:
show-password:
description: "Show username and password in output information"
type: boolean
default: False
Read more: File ‘actions.yaml’, How to handle actions
Define the action event handlers
Open the src/charm.py
file.
In the charm __init__
method, add an action event observer, as below. As you can see, the name of the event consists of the name defined in the actions.yaml
file (get-db-info
) and the word action
# events on custom actions that are run via 'juju run-action'
self.framework.observe(self.on.get_db_info_action, self._on_get_db_info_action)
Read more: Event
<action name>-action
Now, define the action event handler, as below: First, read the value of the parameter defined in the actions.yaml
file (show-password
). Then, use the fetch_postgres_relation_data
method (that we defined in a previous chapter) to read the contents of the database relation data and, if the parameter value read earlier is True
, add the username and password to the output. Finally, use event.set_results
to attach the results to the event that has called the action; this will print the output to the terminal.
def _on_get_db_info_action(self, event) -> None:
show_password = event.params["show-password"] # see actions.yaml
try:
db_data = self.fetch_postgres_relation_data()
output = {
"db-host": db_data.get("db_host", None),
"db-port": db_data.get("db_port", None),
if show_password:
output.update(
"db-username": db_data.get("db_username", None),
"db-password": db_data.get("db_password", None),
except SystemExit:
output = {"result": "No database connected"}
raise
finally:
event.set_results(output)
Validate your charm
First, repack and refresh your charm:
charmcraft pack
juju refresh \
--path="./demo-api-charm_ubuntu-22.04-amd64.charm" \
demo-api-charm --force-units --resource \
demo-server-image=ghcr.io/beliaev-maksim/api_demo_server:0.0.9
Next, test that the basic action invocation works:
juju run demo-api-charm/0 get-db-info --wait 1m
It might take a few seconds, but soon you should see an output similar to the one below, showing the database host and port:
Running operation 13 with 1 task
- task 14 on unit-demo-api-charm-0
Waiting for task 14...
db-host: postgresql-k8s-primary.model2.svc.cluster.local
db-port: "5432"
Now, test that the action parameter (show-password
) works as well by setting it to True
juju run demo-api-charm/0 get-db-info show-password=True --wait 1m
The output should now include the username and the password:
Running operation 15 with 1 task
- task 16 on unit-demo-api-charm-0
Waiting for task 16...
db-password: RGv80aF9WAJJtExn
db-port: "5432"
db-username: relation_id_4
Read more: Juju OLM |
juju run
Congratulations, you now know how to expose operational tasks via actions!
Review the final code
For the full code see: 06_create_actions
For a comparative view of the code before and after this doc see: Comparison
See next: Observe your charm with COS Lite
