This guide describes how to register your Microsoft.Capacity, Microsoft.Storage, and Microsoft.Compute providers required to set up a Canonical Managed application.
If you are already on the Resource Providers page, skip to step 4.
- Go to the Azure
Subscriptionspage by searching on the top bar:
- Click on the subscription you want to use for the setup:
- Search for
providerson the menu search box and click onResource Providers:
- Search for
capacityusing theFilter by namefield:
- You should see that
Microsoft.Capacitystatus isnotRegisteredorunregistered:
- Select it by checking the circle before the name and click
Registeron the top:
- Wait until the provider status changes to
- Now do the same for
Microsoft.Compute. - Search for it using the
Filter by name. - Select it by checking the circle before the name, and click the
Registerbutton. - Wait until the provider changes to
Microsoft.Storage. - Search for it using the
- Once all providers are registered, you need to restart your setup. The easiest way is to close the setup tab in your browser and restart it from the Azure Marketplace.
