The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
See also: clouds, add-cloud, update-cloud
Shows detailed information for a cloud.
Usage
juju show-cloud [options] <cloud name>
Options
Flag | Default | Usage |
-B , --no-browser-login |
-c , --controller |
Controller to operate in | |
--client |
false | Client operation |
--format |
display | Specify output format (display|json|yaml) |
--include-config |
false | Print available config option details specific to the specified cloud |
-o , --output |
Specify an output file |
Examples
juju show-cloud google
juju show-cloud azure-china --output ~/azure_cloud_details.txt
juju show-cloud myopenstack --controller mycontroller
juju show-cloud myopenstack --client
juju show-cloud myopenstack --client --controller mycontroller
Details
Provided information includes ‘defined’ (public, built-in), ‘type’, ‘auth-type’, ‘regions’, ‘endpoints’, and cloud specific configuration options.
If ‘–include-config’ is used, additional configuration (key, type, and description) specific to the cloud are displayed if available.
Use --controller option to show a cloud from a controller.
Use --client option to show a cloud known on this client.
