See also: controllers, model-config, show-cloud
Displays or sets configuration settings for a controller.
Usage
juju controller-config [options] [<attribute key>[=<value>] ...]
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--c, --controller |
Controller to operate in | |
--color |
false | Use ANSI color codes in output |
--file |
path to yaml-formatted configuration file | |
--format |
tabular | Specify output format (json|tabular|yaml) |
--ignore-read-only-fields |
false | Ignore read only fields that might cause errors to be emitted while processing yaml documents |
--no-color |
false | Disable ANSI color codes in tabular output |
--o, --output |
Specify an output file |
Examples
Print all config values for the current controller:
Print the value of “api-port” for the current controller:
juju controller-config api-port
Print all config values for the controller “mycontroller”:
juju controller-config -c mycontroller
Set the “auditing-enabled” and “audit-log-max-backups” keys:
juju controller-config auditing-enabled=true audit-log-max-backups=5
Set the current controller’s config from a yaml file:
juju controller-config --file path/to/file.yaml
Details
To view all configuration values for the current controller, run juju controller-config You can target a specific controller using the -c flag: juju controller-config -c By default, the config will be printed in a tabular format. You can instead print it in json or yaml format using the --format flag: juju controller-config --format json juju controller-config --format yaml
To view the value of a single config key, run juju controller-config key To set config values, run juju controller-config key1=val1 key2=val2 …
Config values can be imported from a yaml file using the --file flag: juju controller-config --file=path/to/cfg.yaml This allows you to e.g. save a controller’s config to a file: juju controller-config --format=yaml > cfg.yaml and then import the config later. Note that the output of controller-config may include read-only values, which will cause an error when importing later. To prevent the error, use the --ignore-read-only-fields flag: juju controller-config --file=cfg.yaml --ignore-read-only-fields
You can also read from stdin using “-”, which allows you to pipe config values
from one controller to another:
juju controller-config -c c1 --format=yaml
| juju controller-config -c c2 --file=- --ignore-read-only-fields
You can simultaneously read config from a yaml file and set config keys
as above. The command-line args will override any values specified in the file.
The following keys are available:
agent-logfile-max-backups: type: int description: The number of old agent log files to keep (compressed) agent-logfile-max-size: type: string description: The maximum size of the agent log file agent-ratelimit-max: type: int description: The maximum size of the token bucket used to ratelimit agent connections agent-ratelimit-rate: type: string description: The time taken to add a new token to the ratelimit bucket api-port-open-delay: type: string description: “The duration that the controller will wait \nbetween when the controller has been deemed to be ready to open \nthe api-port and when the api-port is actually opened \n(only used when a controller-api-port value is set).” application-resource-download-limit: type: int description: The maximum number of concurrent resources downloads per application audit-log-capture-args: type: bool description: Determines if the audit log contains the arguments passed to API methods audit-log-exclude-methods: type: list description: The list of Facade.Method names that aren’t interesting for audit logging purposes. audit-log-max-backups: type: int description: The number of old audit log files to keep (compressed) audit-log-max-size: type: string description: The maximum size for the current controller audit log file auditing-enabled: type: bool description: Determines if the controller records auditing information controller-api-port: type: int description: |- An optional port that may be set for controllers that have a very heavy load. If this port is set, this port is used by the controllers to talk to each other - used for the local API connection as well as the pubsub forwarders, and the raft workers. If this value is set, the api-port isn’t opened until the controllers have started properly. controller-resource-download-limit: type: int description: The maximum number of concurrent resources downloads across all the applications on the controller features: type: list description: A list of runtime changeable features to be updated juju-ha-space: type: string description: The network space within which the MongoDB replica-set should communicate juju-mgmt-space: type: string description: The network space that agents should use to communicate with controllers max-agent-state-size: type: int description: The maximum size (in bytes) of internal state data that agents can store to the controller max-charm-state-size: type: int description: The maximum size (in bytes) of charm-specific state that units can store to the controller max-debug-log-duration: type: string description: The maximum duration that a debug-log session is allowed to run max-prune-txn-batch-size: type: int description: (deprecated) The maximum number of transactions evaluated in one go when pruning max-prune-txn-passes: type: int description: (deprecated) The maximum number of batches processed when pruning migration-agent-wait-time: type: string description: The maximum during model migrations that the migration worker will wait for agents to report on phases of the migration model-logfile-max-backups: type: int description: The number of old model log files to keep (compressed) model-logfile-max-size: type: string description: The maximum size of the log file written out by the controller on behalf of workers running for a model model-logs-size: type: string description: The size of the capped collections used to hold the logs for the models mongo-memory-profile: type: string description: Sets mongo memory profile prune-txn-query-count: type: int description: The number of transactions to read in a single query prune-txn-sleep-time: type: string description: The amount of time to sleep between processing each batch query public-dns-address: type: string description: Public DNS address (with port) of the controller. query-tracing-enabled: type: bool description: Enable query tracing for the dqlite driver query-tracing-threshold: type: string description: “The minimum duration of a query for it to be traced. The lower the \nthreshold, the more queries will be output. A value of 0 means all queries \nwill be output if tracing is enabled.”
