See also: models, model-defaults, show-cloud, controller-config
Displays or sets configuration values on a model.
Usage
juju model-config [options] [<model-key>[=<value>] ...]
Options
| Flag | Default | Usage |
--B, --no-browser-login |
--color |
false | Use ANSI color codes in output |
--file |
path to yaml-formatted configuration file | |
--format |
tabular | Specify output format (json|tabular|yaml) |
--ignore-read-only-fields |
false | Ignore read only fields that might cause errors to be emitted while processing yaml documents |
--m, --model |
--no-color |
false | Disable ANSI color codes in tabular output |
--o, --output |
Specify an output file | |
--reset |
Reset the provided comma delimited keys |
Examples
Print the value of default-base:
juju model-config default-base
Print the model config of model mycontroller:mymodel:
juju model-config -m mycontroller:mymodel
Set the value of ftp-proxy to 10.0.0.1:8000:
juju model-config ftp-proxy=10.0.0.1:8000
Set the model config to key=value pairs defined in a file:
juju model-config --file path/to/file.yaml
Set model config values of a specific model:
juju model-config -m othercontroller:mymodel default-base=ubuntu@22.04 test-mode=false
Reset the values of the provided keys to model defaults:
juju model-config --reset default-base,test-mode
Details
To view all configuration values for the current model, run juju model-config You can target a specific model using the -m flag: juju model-config -m juju model-config -m : By default, the config will be printed in a tabular format. You can instead print it in json or yaml format using the --format flag: juju model-config --format json juju model-config --format yaml
To view the value of a single config key, run juju model-config key To set config values, run juju model-config key1=val1 key2=val2 … You can also reset config keys to their default values: juju model-config --reset key1 juju model-config --reset key1,key2,key3 You may simultaneously set some keys and reset others: juju model-config key1=val1 key2=val2 --reset key3,key4
Config values can be imported from a yaml file using the --file flag: juju model-config --file=path/to/cfg.yaml This allows you to e.g. save a model’s config to a file: juju model-config --format=yaml > cfg.yaml and then import the config later. Note that the output of model-config may include read-only values, which will cause an error when importing later. To prevent the error, use the --ignore-read-only-fields flag: juju model-config --file=cfg.yaml --ignore-read-only-fields
You can also read from stdin using “-”, which allows you to pipe config values
from one model to another:
juju model-config -c c1 --format=yaml
| juju model-config -c c2 --file=- --ignore-read-only-fields
You can simultaneously read config from a yaml file and set config keys
as above. The command-line args will override any values specified in the file.
The default-series key is deprecated in favour of default-base e.g. default-base=ubuntu@22.04.
The following keys are available:
agent-metadata-url: type: string description: URL of private stream agent-stream: type: string description: Version of Juju to use for deploy/upgrades. apt-ftp-proxy: type: string description: The APT FTP proxy for the model apt-http-proxy: type: string description: The APT HTTP proxy for the model apt-https-proxy: type: string description: The APT HTTPS proxy for the model apt-mirror: type: string description: The APT mirror for the model apt-no-proxy: type: string description: List of domain addresses not to be proxied for APT (comma-separated) authorized-keys: type: string description: Any authorized SSH public keys for the model, as found in a ~/.ssh/authorized_keys file automatically-retry-hooks: type: bool description: Determines whether the uniter should automatically retry failed hooks backup-dir: type: string description: Directory used to store the backup working directory charmhub-url: type: string description: The url for CharmHub API calls cloudinit-userdata: type: string description: Cloud-init user-data (in yaml format) to be added to userdata for new machines created in this model container-image-metadata-url: type: string description: The URL at which the metadata used to locate container OS image ids is located container-image-stream: type: string description: The simplestreams stream used to identify which image ids to search when starting a container. container-inherit-properties: type: string description: List of properties to be copied from the host machine to new containers created in this model (comma-separated) container-networking-method: type: string description: Method of container networking setup - one of fan, provider, local default-base: type: string description: The default base image to use for deploying charms, will act like --base when deploying charms default-space: type: string description: The default network space used for application endpoints in this model development: type: bool description: Whether the model is in development mode disable-network-management: type: bool description: Whether the provider should control networks (on MAAS models, set to true for MAAS to control networks disable-telemetry: type: bool description: Disable telemetry reporting of model information egress-subnets: type: string description: Source address(es) for traffic originating from this model enable-os-refresh-update: type: bool description: Whether newly provisioned instances should run their respective OS’s update capability. enable-os-upgrade: type: bool description: Whether newly provisioned instances should run their respective OS’s upgrade capability. extra-info: type: string description: Arbitrary user specified string data that is stored against the model. fan-config: type: string description: Configuration for fan networking for this model firewall-mode: type: string description: |- The mode to use for network firewalling.
'instance' requests the use of an individual firewall per instance.
'global' uses a single firewall for all instances (access
for a network port is enabled to one instance if any instance requires
that port).
'none' requests that no firewalling should be performed
inside the model. It's useful for clouds without support for either
global or per instance security groups.
ftp-proxy: type: string description: The FTP proxy value to configure on instances, in the FTP_PROXY environment variable http-proxy: type: string description: The HTTP proxy value to configure on instances, in the HTTP_PROXY environment variable https-proxy: type: string description: The HTTPS proxy value to configure on instances, in the HTTPS_PROXY environment variable ignore-machine-addresses: type: bool description: Whether the machine worker should discover machine addresses on startup image-metadata-url: type: string description: The URL at which the metadata used to locate OS image ids is located image-stream: type: string description: The simplestreams stream used to identify which image ids to search when starting an instance. juju-ftp-proxy: type: string description: The FTP proxy value to pass to charms in the JUJU_CHARM_FTP_PROXY environment variable juju-http-proxy: type: string description: The HTTP proxy value to pass to charms in the JUJU_CHARM_HTTP_PROXY environment variable juju-https-proxy: type: string description: The HTTPS proxy value to pass to charms in the JUJU_CHARM_HTTPS_PROXY environment variable juju-no-proxy: type: string description: List of domain addresses not to be proxied (comma-separated), may contain CIDRs. Passed to charms in the JUJU_CHARM_NO_PROXY environment variable logforward-enabled: type: bool description: Whether syslog forwarding is enabled. logging-config: type: string description: The configuration string to use when configuring Juju agent logging (see http://godoc.org/github.com/juju/loggo#ParseConfigurationString for details) logging-output: type: string description: ‘The logging output destination: database and/or syslog. (default “”)’ lxd-snap-channel: type: string description: The channel to use when installing LXD from a snap (cosmic and later) max-action-results-age: type: string description: The maximum age for action entries before they are pruned, in human-readable time format max-action-results-size: type: string description: The maximum size for the action collection, in human-readable memory format max-status-history-age: type: string description: The maximum age for status history entries before they are pruned, in human-readable time format max-status-history-size: type: string description: The maximum size for the status history collection, in human-readable memory format mode: type: string description: |- Mode is a comma-separated list which sets the mode the model should run in. So far only one is implemented - If ‘requires-prompts’ is present, clients will ask for confirmation before removing potentially valuable resources. (default “”) net-bond-reconfigure-delay: type: int description: The amount of time in seconds to sleep between ifdown and ifup when bridging no-proxy: type: string description: List of domain addresses not to be proxied (comma-separated) num-container-provision-workers: type: int description: The number of container provisioning workers to use per machine num-provision-workers: type: int description: The number of provisioning workers to use per model provisioner-harvest-mode: type: string description: What to do with unknown machines (default destroyed) proxy-ssh: type: bool description: Whether SSH commands should be proxied through the API server resource-tags: type: attrs description: resource tags saas-ingress-allow: type: string description: |- Application-offer ingress allowlist is a comma-separated list of CIDRs specifying what ingress can be applied to offers in this model. secret-backend: type: string description: The name of the secret store backend. (default “auto”) snap-http-proxy: type: string description: The HTTP proxy value to for installing snaps snap-https-proxy: type: string description: The HTTPS proxy value to for installing snaps snap-store-assertions: type: string description: The assertions for the defined snap store proxy snap-store-proxy: type: string description: The snap store proxy for installing snaps snap-store-proxy-url: type: string description: The URL for the defined snap store proxy ssh-allow: type: string description: |- SSH allowlist is a comma-separated list of CIDRs from which machines in this model will accept connections to the SSH service. Currently only the aws provider supports ssh-allow ssl-hostname-verification: type: bool description: Whether SSL hostname verification is enabled (default true) storage-default-block-source: type: string description: The default block storage source for the model storage-default-filesystem-source: type: string description: The default filesystem storage source for the model syslog-ca-cert: type: string description: The certificate of the CA that signed the syslog server certificate, in PEM format. syslog-client-cert: type: string description: The syslog client certificate in PEM format. syslog-client-key: type: string description: The syslog client key in PEM format. syslog-host: type: string description: The hostname:port of the syslog server. test-mode: type: bool description: |- Whether the model is intended for testing. If true, accessing the charm store does not affect statistical data of the store. (default false) transmit-vendor-metrics: type: bool description: Determines whether metrics declared by charms deployed into this model are sent for anonymized aggregate analytics update-status-hook-interval: type: string description: How often to run the charm update-status hook, in human-readable time format (default 5m, range 1-60m)
