Command 'bootstrap'
See also: add-credential, autoload-credentials, add-model, controller-config, model-config, set-constraints, show-cloud
Initializes a cloud environment.
Usage
juju bootstrap [options] [<cloud name>[/region] [<controller name>]]
Options
Flag Default Usage
--B, --no-browser-login false Do not use web browser for authentication
--add-model Name of an initial model to create on the new controller
--agent-version Version of agent binaries to use for Juju agents
--auto-upgrade false After bootstrap, upgrade to the latest patch release
--bootstrap-base Specify the base of the bootstrap machine
--bootstrap-constraints Specify bootstrap machine constraints
--bootstrap-image Specify the image of the bootstrap machine (requires --bootstrap-constraints specifying architecture)
--bootstrap-series Specify the series of the bootstrap machine (deprecated use bootstrap-base)
--build-agent false Build local version of agent binary before bootstrapping
--clouds false Print the available clouds which can be used to bootstrap a Juju environment
--config Specify a controller configuration file, or one or more configuration
options
(--config config.yaml [--config key=value ...]) |
| --constraints | | Set model constraints | | --controller-charm-channel | 3.3/stable | The Charmhub channel to download the controller charm from (if not using a local charm) | | --controller-charm-path | | Path to a locally built controller charm | | --credential | | Credentials to use when bootstrapping | | --db-snap | | Path to a locally built .snap to use as the internal juju-db service. | | --db-snap-asserts | | Path to a local .assert file. Requires --db-snap | | --force | false | Allow the bypassing of checks such as supported series | | --keep-broken | false | Do not destroy the provisioned controller instance if bootstrap fails | | --metadata-source | | Local path to use as agent and/or image metadata source | | --model-default | | Specify a configuration file, or one or more configuration options to be set for all models, unless otherwise specified (–model-default config.yaml [–model-default key=value …]) | | --no-switch | false | Do not switch to the newly created controller | | --regions | | Print the available regions for the specified cloud | | --storage-pool | | Specify options for an initial storage pool ‘name’ and ‘type’ are required, plus any additional attributes (–storage-pool pool-config.yaml [–storage-pool key=value …]) | | --to | | Placement directive indicating an instance to bootstrap |
Examples
juju bootstrap
juju bootstrap --clouds
juju bootstrap --regions aws
juju bootstrap aws
juju bootstrap aws/us-east-1
juju bootstrap google joe-us-east1
juju bootstrap --config=~/config-rs.yaml google joe-syd
juju bootstrap --agent-version=2.2.4 aws joe-us-east-1
juju bootstrap --config bootstrap-timeout=1200 azure joe-eastus
juju bootstrap aws --storage-pool name=secret --storage-pool type=ebs --storage-pool encrypted=true
juju bootstrap lxd --bootstrap-base=ubuntu@22.04
# For a bootstrap on k8s, setting the service type of the Juju controller service to LoadBalancer
juju bootstrap --config controller-service-type=loadbalancer
# For a bootstrap on k8s, setting the service type of the Juju controller service to External
juju bootstrap --config controller-service-type=external --config controller-external-name=controller.juju.is
Details
Used without arguments, bootstrap will step you through the process of initializing a Juju cloud environment. Initialization consists of creating a ‘controller’ model and provisioning a machine to act as controller.
We recommend you call your controller ‘username-region’ e.g. ‘fred-us-east-1’ See --clouds for a list of clouds and credentials. See --regions <cloud> for a list of available regions for a given cloud.
Credentials are set beforehand and are distinct from any other configuration (see juju add-credential). The ‘controller’ model typically does not run workloads. It should remain pristine to run and manage Juju’s own infrastructure for the corresponding cloud. Additional models should be created with juju add-model for workload purposes. Note that a ‘default’ model is also created and becomes the current model of the environment once the command completes. It can be discarded if other models are created.
If ‘–bootstrap-constraints’ is used, its values will also apply to any future controllers provisioned for high availability (HA).
If ‘–constraints’ is used, its values will be set as the default constraints for all future workload machines in the model, exactly as if the constraints were set with juju set-model-constraints.
It is possible to override constraints and the automatic machine selection algorithm by assigning a “placement directive” via the ‘–to’ option. This dictates what machine to use for the controller. This would typically be used with the MAAS provider (‘–to <host>.maas’).
You can change the default timeout and retry delays used during the bootstrap by changing the following settings in your configuration (all values represent number of seconds): # How long to wait for a connection to the controller bootstrap-timeout: 1200 # default: 20 minutes # How long to wait between connection attempts to a controller address. bootstrap-retry-delay: 5 # default: 5 seconds # How often to refresh controller addresses from the API server. bootstrap-addresses-delay: 10 # default: 10 seconds
It is possible to override the base e.g. ubuntu@22.04, Juju attempts to bootstrap on to, by supplying a base argument to ‘–bootstrap-base’.
An error is emitted if the determined base is not supported. Using the ‘–force’ option to override this check:
juju bootstrap --bootstrap-base=ubuntu@22.04 --force
The ‘–bootstrap-series’ can be still used, but is deprecated in favour of ‘–bootstrap-base’.
Private clouds may need to specify their own custom image metadata and tools/agent. Use ‘–metadata-source’ whose value is a local directory.
By default, the Juju version of the agent binary that is downloaded and installed on all models for the new controller will be the same as that of the Juju client used to perform the bootstrap. However, a user can specify a different agent version via ‘–agent-version’ option to bootstrap command. Juju will use this version for models’ agents as long as the client’s version is from the same Juju release series. In other words, a 2.2.1 client can bootstrap any 2.2.x agents but cannot bootstrap any 2.0.x or 2.1.x agents. The agent version can be specified a simple numeric version, e.g. 2.2.4.
For example, at the time when 2.3.0, 2.3.1 and 2.3.2 are released and your agent stream is ‘released’ (default), then a 2.3.1 client can bootstrap: * 2.3.0 controller by running ‘… bootstrap --agent-version=2.3.0 …’; * 2.3.1 controller by running ‘… bootstrap …’; * 2.3.2 controller by running ‘bootstrap --auto-upgrade’. However, if this client has a copy of codebase, then a local copy of Juju will be built and bootstrapped - 2.3.1.1.
Bootstrapping to a k8s cluster requires that the service set up to handle requests to the controller be accessible outside the cluster. Typically this means a service type of LoadBalancer is needed, and Juju does create such a service if it knows it is supported by the cluster. This is performed by interrogating the cluster for a well known managed deployment such as microk8s, GKE or EKS.
When bootstrapping to a k8s cluster Juju does not recognise, there’s no guarantee a load balancer is available, so Juju defaults to a controller service type of ClusterIP. This may not be suitable, so there’s 3 bootstrap options available to tell Juju how to set up the controller service. Part of the solution may require a load balancer for the cluster to be set up manually first, or perhaps an external k8s service via a FQDN will be used (this is a cluster specific implementation decision which Juju needs to be informed about so it can set things up correctly). The 3 relevant bootstrap options are (see list of bootstrap config items below for a full explanation):
  • controller-service-type
  • controller-external-name
  • controller-external-ips
If a storage pool is specified using --storage-pool, this will be created in the controller model.
Available keys for use with --config are:
admin-secret: type: string description: Sets the Juju administrator password agent-logfile-max-backups: type: int description: The number of old agent log files to keep (compressed) agent-logfile-max-size: type: string description: The maximum size of the agent log file agent-metadata-url: type: string description: URL of private stream agent-ratelimit-max: type: int description: The maximum size of the token bucket used to ratelimit agent connections agent-ratelimit-rate: type: string description: The time taken to add a new token to the ratelimit bucket agent-stream: type: string description: Version of Juju to use for deploy/upgrades. allow-model-access: type: bool description: “Determines if the controller allows users to \nconnect to models they have been authorized for even when \nthey don’t have any access rights to the controller itself” api-port: type: int description: The port used for api connections api-port-open-delay: type: string description: “The duration that the controller will wait \nbetween when the controller has been deemed to be ready to open \nthe api-port and when the api-port is actually opened \n(only used when a controller-api-port value is set).” application-resource-download-limit: type: int description: The maximum number of concurrent resources downloads per application apt-ftp-proxy: type: string description: The APT FTP proxy for the model apt-http-proxy: type: string description: The APT HTTP proxy for the model apt-https-proxy: type: string description: The APT HTTPS proxy for the model apt-mirror: type: string description: The APT mirror for the model apt-no-proxy: type: string description: List of domain addresses not to be proxied for APT (comma-separated) audit-log-capture-args: type: bool description: Determines if the audit log contains the arguments passed to API methods audit-log-exclude-methods: type: list description: The list of Facade.Method names that aren’t interesting for audit logging purposes. audit-log-max-backups: type: int description: The number of old audit log files to keep (compressed) audit-log-max-size: type: string description: The maximum size for the current controller audit log file auditing-enabled: type: bool description: Determines if the controller records auditing information authorized-keys: type: string description: Any authorized SSH public keys for the model, as found in a ~/.ssh/authorized_keys file autocert-dns-name: type: string description: The DNS name of the controller autocert-url: type: string description: The URL used to obtain official TLS certificates when a client connects to the API automatically-retry-hooks: type: bool description: Determines whether the uniter should automatically retry failed hooks backup-dir: type: string description: Directory used to store the backup working directory bootstrap-addresses-delay: type: int description: Controls the amount of time in seconds in between refreshing the bootstrap machine addresses bootstrap-retry-delay: type: int description: Controls the amount of time in seconds between attempts to connect to a bootstrap machine address bootstrap-timeout: type: int description: Controls how long Juju will wait for a bootstrap to complete before considering it failed in seconds ca-cert: type: string description: Sets the bootstrapped controllers CA cert to use and issue certificates from, used in conjunction with ca-private-key ca-private-key: type: string description: Sets the bootstrapped controllers CA cert private key to sign certificates with, used in conjunction with ca-cert caas-image-repo: type: string description: The docker repo to use for the jujud operator and mongo images caas-operator-image-path: type: string description: |- (deprected) The url of the docker image used for the application operator. Use “caas-image-repo” instead. charmhub-url: type: string description: The url for CharmHub API calls cloudinit-userdata: type: string description: Cloud-init user-data (in yaml format) to be added to userdata for new machines created in this model container-image-metadata-url: type: string description: The URL at which the metadata used to locate container OS image ids is located container-image-stream: type: string description: The simplestreams stream used to identify which image ids to search when starting a container. container-inherit-properties: type: string description: List of properties to be copied from the host machine to new containers created in this model (comma-separated) container-networking-method: type: string description: Method of container networking setup - one of fan, provider, local controller-api-port: type: int description: |- An optional port that may be set for controllers that have a very heavy load. If this port is set, this port is used by the controllers to talk to each other - used for the local API connection as well as the pubsub forwarders, and the raft workers. If this value is set, the api-port isn’t opened until the controllers have started properly. controller-external-ips: type: list description: Specifies a comma separated list of external IPs for a k8s controller of type external controller-external-name: type: string description: Sets the external name for a k8s controller of type external controller-resource-download-limit: type: int description: The maximum number of concurrent resources downloads across all the applications on the controller controller-service-type: type: string description: Controls the kubernetes service type for Juju controllers, see https://kubernetes.io/docs/reference/generated/kubernetes-api/v1.19/#servicespec-v1-core valid values are one of cluster, loadbalancer, external default-base: type: string description: The default base image to use for deploying charms, will act like --base when deploying charms default-space: type: string description: The default network space used for application endpoints in this model development: type: bool description: Whether the model is in development mode disable-network-management: type: bool description: Whether the provider should control networks (on MAAS models, set to true for MAAS to control networks disable-telemetry: type: bool description: Disable telemetry reporting of model information egress-subnets: type: string description: Source address(es) for traffic originating from this model enable-os-refresh-update: type: bool description: Whether newly provisioned instances should run their respective OS’s update capability. enable-os-upgrade: type: bool description: Whether newly provisioned instances should run their respective OS’s upgrade capability. extra-info: type: string description: Arbitrary user specified string data that is stored against the model. fan-config: type: string description: Configuration for fan networking for this model features: type: list description: A list of runtime changeable features to be updated firewall-mode: type: string description: |- The mode to use for network firewalling.
'instance' requests the use of an individual firewall per instance.
'global' uses a single firewall for all instances (access
for a network port is enabled to one instance if any instance requires
that port).
'none' requests that no firewalling should be performed
inside the model. It's useful for clouds without support for either
global or per instance security groups.
ftp-proxy: type: string description: The FTP proxy value to configure on instances, in the FTP_PROXY environment variable http-proxy: type: string description: The HTTP proxy value to configure on instances, in the HTTP_PROXY environment variable https-proxy: type: string description: The HTTPS proxy value to configure on instances, in the HTTPS_PROXY environment variable identity-public-key: type: string description: The public key of the identity manager identity-url: type: string description: The url of the identity manager ignore-machine-addresses: type: bool description: Whether the machine worker should discover machine addresses on startup image-metadata-url: type: string description: The URL at which the metadata used to locate OS image ids is located image-stream: type: string description: The simplestreams stream used to identify which image ids to search when starting an instance. juju-db-snap-channel: type: string description: Sets channel for installing mongo snaps when bootstrapping on focal or later juju-ftp-proxy: type: string description: The FTP proxy value to pass to charms in the JUJU_CHARM_FTP_PROXY environment variable juju-ha-space: type: string description: The network space within which the MongoDB replica-set should communicate juju-http-proxy: type: string description: The HTTP proxy value to pass to charms in the JUJU_CHARM_HTTP_PROXY environment variable juju-https-proxy: type: string description: The HTTPS proxy value to pass to charms in the JUJU_CHARM_HTTPS_PROXY environment variable juju-mgmt-space: type: string description: The network space that agents should use to communicate with controllers juju-no-proxy: type: string description: List of domain addresses not to be proxied (comma-separated), may contain CIDRs. Passed to charms in the JUJU_CHARM_NO_PROXY environment variable logforward-enabled: type: bool description: Whether syslog forwarding is enabled. logging-config: type: string description: The configuration string to use when configuring Juju agent logging (see http://godoc.org/github.com/juju/loggo#ParseConfigurationString for details) logging-output: type: string description: ‘The logging output destination: database and/or syslog. (default “”)’ login-token-refresh-url: type: string description: The url of the jwt well known endpoint lxd-snap-channel: type: string description: The channel to use when installing LXD from a snap (cosmic and later) max-action-results-age: type: string description: The maximum age for action entries before they are pruned, in human-readable time format max-action-results-size: type: string description: The maximum size for the action collection, in human-readable memory format max-agent-state-size: type: int description: The maximum size (in bytes) of internal state data that agents can store to the controller max-charm-state-size: type: int description: The maximum size (in bytes) of charm-specific state that units can store to the controller max-debug-log-duration: type: string description: The maximum duration that a debug-log session is allowed to run max-prune-txn-batch-size: type: int description: (deprecated) The maximum number of transactions evaluated in one go when pruning max-prune-txn-passes: type: int description: (deprecated) The maximum number of batches processed when pruning max-status-history-age: type: string description: The maximum age for status history entries before they are pruned, in human-readable time format max-status-history-size: type: string description: The maximum size for the status history collection, in human-readable memory format max-txn-log-size: type: string description: The maximum size the of capped txn log collection metering-url: type: string description: The url for metrics migration-agent-wait-time: type: string description: The maximum during model migrations that the migration worker will wait for agents to report on phases of the migration mode: type: string description: |- Mode is a comma-separated list which sets the mode the model should run in. So far only one is implemented - If ‘requires-prompts’ is present, clients will ask for confirmation before removing potentially valuable resources. (default “”) model-logfile-max-backups: type: int description: The number of old model log files to keep (compressed) model-logfile-max-size: type: string description: The maximum size of the log file written out by the controller on behalf of workers running for a model model-logs-size: type: string description: The size of the capped collections used to hold the logs for the models mongo-memory-profile: type: string description: Sets mongo memory profile net-bond-reconfigure-delay: type: int description: The amount of time in seconds to sleep between ifdown and ifup when bridging no-proxy: type: string description: List of domain addresses not to be proxied (comma-separated) num-container-provision-workers: type: int description: The number of container provisioning workers to use per machine num-provision-workers: type: int description: The number of provisioning workers to use per model provisioner-harvest-mode: type: string description: What to do with unknown machines (default destroyed) proxy-ssh: type: bool description: Whether SSH commands should be proxied through the API server prune-txn-query-count: type: int description: The number of transactions to read in a single query prune-txn-sleep-time: type: string description: The amount of time to sleep between processing each batch query public-dns-address: type: string description: Public DNS address (with port) of the controller. query-tracing-enabled: type: bool description: Enable query tracing for the dqlite driver query-tracing-threshold: type: string description: “The minimum duration of a query for it to be traced. The lower the \nthreshold, the more queries will be output. A value of 0 means all queries \nwill be output if tracing is enabled.” resource-tags: type: attrs description: resource tags saas-ingress-allow: type: string description: |- Application-offer ingress allowlist is a comma-separated list of CIDRs specifying what ingress can be applied to offers in this model. secret-backend: type: string description: The name of the secret store backend. (default “auto”) set-numa-control-policy: type: bool description: Determines if the NUMA control policy is set snap-http-proxy: type: string description: The HTTP proxy value to for installing snaps snap-https-proxy: type: string description: The HTTPS proxy value to for installing snaps snap-store-assertions: type: string description: The assertions for the defined snap store proxy snap-store-proxy: type: string description: The snap store proxy for installing snaps snap-store-proxy-url: type: string description: The URL for the defined snap store proxy ssh-allow: type: string description: |- SSH allowlist is a comma-separated list of CIDRs from which machines in this model will accept connections to the SSH service. Currently only the aws provider supports ssh-allow ssl-hostname-verification: type: bool description: Whether SSL hostname verification is enabled (default true) state-port: type: int description: The port used for mongo connections storage-default-block-source: type: string description: The default block storage source for the model storage-default-filesystem-source: type: string description: The default filesystem storage source for the model syslog-ca-cert: type: string description: The certificate of the CA that signed the syslog server certificate, in PEM format. syslog-client-cert: type: string description: The syslog client certificate in PEM format. syslog-client-key: type: string description: The syslog client key in PEM format. syslog-host: type: string description: The hostname:port of the syslog server. test-mode: type: bool description: |- Whether the model is intended for testing. If true, accessing the charm store does not affect statistical data of the store. (default false) transmit-vendor-metrics: type: bool description: Determines whether metrics declared by charms deployed into this model are sent for anonymized aggregate analytics update-status-hook-interval: type: string description: How often to run the charm update-status hook, in human-readable time format (default 5m, range 1-60m)
