Charmed Temporal K8s How To - Upgrade from latest/stable to 1.23/stable
Upgrade Charmed Temporal latest/stable to 1.23/stable
This guide describes how to upgrade an existing Charmed Temporal deployment from the latest/stable channel to the 1.23/stable channel. It is intended for operators who already have a Charmed Temporal deployment running.
The guide has been validated end-to-end on Juju 3.6.21.
Important
Read these notes before starting the upgrade.
  • The schema migration is forward-only. There is no in-place downgrade. If the upgrade fails, the recovery path is restore-from-PostgreSQL-backup either back to latest/stable or directly on 1.23/stable once the underlying issue is resolved.
  • The Temporal charms change their base from ubuntu@22.04 to ubuntu@24.04 between latest/stable and 1.23/stable.
  • temporal-ui-k8s requires the new temporal-host-info relation and will block until it is integrated. temporal-admin-k8s accepts the deprecated server-name config as a fallback.
  • The tctl action on temporal-admin-k8s was renamed to cli in 1.23, and the underlying binary changed from the legacy tctl to the modern temporal CLI with different argument grammar. Operator scripts that call juju run temporal-admin/0 tctl args="..." must be updated.
Deprecation notice: server-name
The server-name config option on temporal-admin-k8s is deprecated in 1.23 and will be removed in a future release. Its only purpose in 1.23 is to act as a fallback when the temporal-host-info relation is absent. The supported configuration is to integrate the temporal-host-info relation and leave server-name unset. Do not introduce new dependencies on server-name.
Step 1: Back up PostgreSQL
The single source of truth for workflow history and namespace metadata is the PostgreSQL backend. Back it up before the refresh.
Recommendation: stop active work before the backup.
Temporal can recover from a database backup without needing a clean shutdown first, so this step is optional. That said, backing up while the system is quiet lowers the risk of capturing incomplete workflow state. If you can, do the following before running the backup:
  • Stop new workflow starts - pause or disable anything that triggers new executions (cron jobs, API clients, schedules).
  • Wait for running workflows to finish - or at least reach a point where they are waiting on a timer, activity, or signal.
  • Shut down workers gracefully - send a shutdown signal so the SDK can finish cleanly. In the Python SDK, worker.run() handles SIGINT/SIGTERM this way by default.
Follow the official postgresql-k8s backup procedure: Create a backup. The how-to covers configuring an S3 backup target, taking a backup, and verifying it.
If the upgrade fails at any point, restoring this dump and redeploying on latest/stable returns the cluster to its pre-upgrade state. See Recovery for the full procedure.
Step 2: Refresh temporal-admin-k8s
The admin charm owns schema management and must be refreshed first.
juju refresh temporal-admin --channel 1.23/stable --base ubuntu@24.04
After settling, temporal-admin reports active status.
Note: The temporal-host-info relation cannot be integrated yet because temporal-k8s has not been refreshed and does not yet provide the endpoint. The relation will be integrated in Step 5 after temporal-k8s is refreshed.
Step 3: Refresh temporal-ui-k8s
The UI charm in 1.23 strictly requires the new temporal-host-info relation. After refresh, it will go to blocked status with the message temporal-host-info relation not established. This is the expected state until Step 5.
Service availability. The Temporal UI is unavailable from the moment the UI pod starts replacing until the temporal-host-info relation is integrated in Step 5.
juju refresh temporal-ui --channel 1.23/stable --base ubuntu@24.04
Step 4: Refresh temporal-k8s
juju refresh temporal-k8s --channel 1.23/stable --base ubuntu@24.04
Step 5: Integrate the temporal-host-info relation
Both temporal-ui and temporal-admin need this relation in 1.23. Add both, and clear the deprecated server-name fallback so the relation becomes the single source of truth.
Reset the deprecated server-name config on temporal-admin:
juju config temporal-admin --reset server-name
Integrate the temporal-host-info relation:
juju integrate temporal-k8s:temporal-host-info temporal-ui:temporal-host-info
juju integrate temporal-k8s:temporal-host-info temporal-admin:temporal-host-info
After this step every application should be active/idle. Confirm the admin cli action is on the relation path (no longer the deprecated fallback):
juju run temporal-admin/0 cli args="operator namespace describe --namespace <your-namespace>"
Step 6: (Optional) Insert pgbouncer-k8s between Temporal and PostgreSQL
The 1.23 solution recommends placing pgbouncer-k8s between Temporal services and PostgreSQL for connection pooling. This is a topology change, separate from the channel refresh.
juju deploy pgbouncer-k8s pgbouncer --channel 1/stable --trust
juju integrate pgbouncer:backend-database postgres:database
# Remove the direct postgres relations, then add the pgbouncer-fronted ones
juju remove-relation temporal-k8s:db          postgres:database
juju remove-relation temporal-k8s:visibility  postgres:database
juju integrate       temporal-k8s:db          pgbouncer:database
juju integrate       temporal-k8s:visibility  pgbouncer:database
Recovery
If an upgrade or schema migration fails, stop further refreshes. Capture the deployment status and Juju debug logs for investigation:
juju status
juju debug-log --include temporal-admin/0
juju debug-log --include temporal-k8s/0
For a failed upgrade-charm hook, inspect the traceback and resolve the underlying issue before retrying.
Juju can be configured to automatically retry failed hooks:
juju model-config automatically-retry-hooks=true
Enable this only after correcting the underlying failure; it does not repair incompatible charm packages or failed database operations.
Do not downgrade charms against a database that has already undergone a forward schema migration. Follow the PostgreSQL restore procedure using a validated backup taken before the failed upgrade.
