Charmed Temporal K8s Tutorial - Deploy PostgreSQL Database
This is part of the Charmed Temporal Tutorial. Please refer to this page for more information and the overview of the content.
For Temporal persistence and visibility, we use the PostgreSQL K8s charmed operator. The PostgreSQL K8s charm can be deployed and related to the Temporal server.
Requirements
Deploy PostgreSQL
To deploy Charmed PostgreSQL K8s, you need to run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy postgresql-k8s --channel 14/stable
Wait for PostgreSQL to become active:
juju status
Wait until the application is ready - when it is ready, juju status will show:
Model           Controller           Cloud/Region  Version  SLA          Timestamp
temporal-model  temporal-controller  ck8s          3.6.9    unsupported  22:32:26Z
App             Version  Status   Scale  Charm           Channel       Rev  Address         Exposed  Message
postgresql-k8s  14.15    active       1  postgresql-k8s  14/stable     495  10.152.183.200  no
temporal-k8s             blocked      1  temporal-k8s    1.31/stable    68  10.152.183.120  no       database relation not ready
Unit               Workload  Agent  Address     Ports  Message
postgresql-k8s/0*  active    idle   10.1.0.36          Primary
temporal-k8s/0*    blocked   idle   10.1.0.152         database relation not ready
Create relations
Temporal requires two PostgreSQL relations: db and visibility.
juju integrate temporal-k8s:db          postgresql-k8s:database
juju integrate temporal-k8s:visibility  postgresql-k8s:database
Check relations:
juju status --relations
Wait until the application is ready. Once it is ready, it shows the following:
temporal-model  temporal-controller  ck8s          3.6.9    unsupported  22:35:07Z
temporal-k8s             blocked      1  temporal-k8s    1.31/stable    68  10.152.183.120  no       admin:temporal relation: schema is not ready
temporal-k8s/0*    blocked   idle   10.1.0.152         admin:temporal relation: schema is not ready
Integration provider           Requirer                       Interface          Type     Message
postgresql-k8s:database        temporal-k8s:db                postgresql_client  regular
postgresql-k8s:database        temporal-k8s:visibility        postgresql_client  regular
postgresql-k8s:database-peers  postgresql-k8s:database-peers  postgresql_peers   peer
postgresql-k8s:restart         postgresql-k8s:restart         rolling_op         peer
postgresql-k8s:upgrade         postgresql-k8s:upgrade         upgrade            peer
temporal-k8s:peer              temporal-k8s:peer              temporal           peer
At this point, the server may still show that the schema is not ready. This is expected. The schema will be created after deploying and relating Temporal Admin in the next step.
Production note: PgBouncer
For production deployments, consider placing pgbouncer-k8s between Temporal and PostgreSQL for connection pooling. PgBouncer mediates connections from Temporal to the database, which reduces connection churn under load.
PgBouncer is not required for this tutorial, but operators planning a production deployment can review the upgrade from latest to 1.23 Step 6 for the procedure.
See next: Deploy Temporal Admin
