Charmed Temporal K8s How To - Configure the Temporal worker
This guide describes the configuration surface of the temporal-worker-k8s charm. Each section below covers one concern (server connection, authentication, observability, …); apply only the sections that match your environment. The full list of options is also available on the auto-generated Configurations page.
This guide assumes you have already deployed the worker - see the Deploy Temporal Worker tutorial if you have not.
Connect to a Temporal server
The worker connects to a Temporal frontend through the temporal-host-info relation, provided by the temporal-k8s charm. This is the supported and recommended path:
juju integrate temporal-k8s:temporal-host-info temporal-worker-k8s:temporal-host-info
For cross-model deployments, use a cross-model relation (juju offer + juju consume + juju integrate). See the tutorial for the full sequence.
Deprecation notice: host config. The host config is deprecated in 1.23/stable and will be removed in a future release. It is only consulted as a fallback when the temporal-host-info relation is absent. Do not introduce new dependencies on host.
Set the namespace and task queue
The worker polls a single (namespace, task-queue) pair. Configure both:
juju config temporal-worker-k8s namespace=your-namespace queue=your-queue
These options have no defaults - the worker will block until both are set.
Inject environment variables into the worker
The environment config injects values into the worker container at runtime. Values can come from three sources - plain environment variables, Juju secrets, or HashiCorp Vault and you can mix them in a single environment.yaml file. The worker resolves values in the order: Vault → Juju secrets → plain env vars.
Apply the file with:
juju config temporal-worker-k8s environment=@/path/to/environment.yaml
Workflow code reads the values via os.getenv("KEY").
Plain environment variables
For non-sensitive values such as the deployment environment label:
# environment.yaml
env:
- name: APP_ENV
value: production
- name: REGION
value: eu-west-1
Do not put plain secrets in the env: section. Anything here is visible in juju config output. Use the juju: or vault: sections for sensitive values.
Juju user secrets (Juju 3.3+)
Add a secret to the Juju model and grant the worker access:
juju add-secret my-secret key1=value1 key2=value2
juju grant-secret my-secret temporal-worker-k8s
Then reference the secret in environment.yaml:
juju:
- secret-id: <secret-id-from-add-secret>
key: key1
key: key2
- secret-id: <other-secret-id> # reads all keys; injects them as SCREAMING_SNAKE_CASE env vars
If a juju: entry omits name and key, the charm reads all keys from that secret and injects each one as a SCREAMING_SNAKE_CASE environment variable (e.g. access-token → ACCESS_TOKEN).
HashiCorp Vault
Once the Vault relation is established (see Use HashiCorp Vault for runtime secrets below), reference Vault paths in environment.yaml:
vault:
- path: my-secrets
key: key1
- path: my-secrets
key: key2
Use Juju secrets for authentication
The supported way to give the worker its auth and encryption material is to put it in a Juju secret and point the charm at the secret via auth-secret-id.
What keys the secret accepts
The secret can contain any of the following keys; only include the ones relevant to your auth provider.
| Group | Keys | Used when |
| Encryption | encryption-key | Always supported; base64-encoded data encryption key |
| Auth provider | auth-provider | Set to either candid or google |
| Candid | candid-url, candid-username, candid-public-key, candid-private-key | auth-provider=candid |
| OIDC (Google) | oidc-auth-type, oidc-project-id, oidc-private-key-id, oidc-private-key, oidc-client-email, oidc-client-id, oidc-auth-uri, oidc-token-uri, oidc-auth-cert-url, oidc-client-cert-url | auth-provider=google |
Create the secret and wire it up
juju add-secret temporal-worker-auth \
encryption-key=<base64-key> \
auth-provider=google \
oidc-auth-type=service_account \
oidc-project-id=<gcp-project-id> \
oidc-private-key-id=<...> \
oidc-private-key=<...> \
oidc-client-email=<...> \
oidc-client-id=<...> \
oidc-auth-uri=<...> \
oidc-token-uri=<...> \
oidc-auth-cert-url=<...> \
oidc-client-cert-url=<...>
juju grant-secret temporal-worker-auth temporal-worker-k8s
juju config temporal-worker-k8s auth-secret-id=<secret-id-from-add-secret>
Replace the oidc-* block with the four candid-* keys if auth-provider=candid.
auth-secret-id takes precedence over the individual auth-related charm config options (encryption-key, auth-provider, candid-*, oidc-*). Those individual config options are deprecated and will be removed in a future release - set everything via the secret instead.
For a focused walkthrough of OAuth / Google Cloud service-account authentication including obtaining the OIDC values, see the How to configure authentication guide.
The worker can pull secrets from a Vault instance at runtime, in addition to or instead of Juju secrets. This is the recommended option for production environments where workflow code needs database credentials, API keys, or other rotating secrets.
  1. Deploy and unseal vault-k8s. Vault requires a manual initialisation and unseal step before it can serve secrets - follow the vault-k8s operator instructions.
juju deploy vault-k8s --channel 1.16/edge
# ... follow the vault-k8s docs to initialise and unseal ...
  1. Integrate the worker with vault-k8s:
juju integrate temporal-worker-k8s:vault vault-k8s
  1. Add a secret to Vault via the worker’s action:
juju run temporal-worker-k8s/leader add-vault-secret \
path=<secret-path> key=<secret-key> value=<secret-value>
  1. Read it back to verify:
juju run temporal-worker-k8s/leader get-vault-secret \
  1. Reference the Vault-backed values in your environment.yaml under the vault: section (see Inject environment variables into the worker).
Vault must be unsealed every time it restarts. If the Temporal worker enters blocked after a Vault unit restart, check the Vault unit status, workflow runs will fail until Vault is unsealed.
Configure TLS for the Temporal server connection
If the Temporal frontend uses TLS with a non-system-trusted CA, set the root CA(s) via tls-root-cas:
juju config temporal-worker-k8s tls-root-cas="$(cat ca-bundle.pem)"
The value is a PEM-encoded bundle. The worker presents these CAs when validating the frontend’s certificate.
Configure Sentry for error reporting
The worker can report unhandled errors to a Sentry project:
juju config temporal-worker-k8s \
sentry-dsn=https://<key>@<org>.ingest.sentry.io/<project> \
sentry-environment=production \
sentry-release=2026.05.01 \
sentry-sample-rate=1.0 \
sentry-redact-params=true
| Option | Purpose | Default |
| sentry-dsn | Sentry DSN to send events to | empty (Sentry disabled) |
| sentry-environment | Free-form environment label | empty |
| sentry-release | Release identifier (e.g. version, commit) | empty |
| sentry-sample-rate | Fraction of errors to capture (0.0–1.0) | 1.0 |
| sentry-redact-params | Redact event parameters before sending | false |
Leave sentry-dsn empty to disable Sentry entirely.
Connect to a PostgreSQL database
If the worker’s workflows need a relational database, integrate the worker with postgresql-k8s and configure a database name:
juju deploy postgresql-k8s --channel 14/stable --trust
juju integrate temporal-worker-k8s:database postgresql-k8s:database
juju config temporal-worker-k8s db-name=your-db-name
Once the relation is active, the charm injects the following environment variables into the worker container, workflow code can reference them directly:
| Env var | Contains |
| TEMPORAL_DB_NAME | Database name (matches db-name config) |
| TEMPORAL_DB_HOST | PostgreSQL host |
| TEMPORAL_DB_PORT | PostgreSQL port |
| TEMPORAL_DB_USER | DB username provisioned for the relation |
| TEMPORAL_DB_PASSWORD | DB password provisioned for the relation |
| TEMPORAL_DB_TLS | Whether the relation uses TLS |
The relation is optional, only integrate it if the workflows actually consume a database connection.
Set the log level
juju config temporal-worker-k8s log-level=debug
Acceptable values: info (default), debug, warning, error, critical.
Use an HTTP proxy
If the workload container needs to reach the Temporal server (or any other endpoint) through an HTTP proxy, set the proxy on the Juju model. The charm reads these values and injects HTTP_PROXY, HTTPS_PROXY, and NO_PROXY into the workload container.
juju model-config juju-http-proxy=<http-proxy-url>
juju model-config juju-https-proxy=<https-proxy-url>
juju model-config juju-no-proxy=<no-proxy-list>
If the worker is already deployed when you change these, trigger a reconciliation (e.g. juju config temporal-worker-k8s log-level=info or run the restart action below) so the new env vars take effect.
Restart the worker
Some config changes require a worker restart to take effect. The charm exposes a restart action:
juju run temporal-worker-k8s/0 restart
Reset a config option
To revert any option to its default, use --reset:
juju config temporal-worker-k8s --reset host
juju config temporal-worker-k8s --reset sentry-dsn
--reset is the migration command for moving off deprecated options once their replacement is wired up.
See also
