Deploy Temporal worker
Requirements
rockcraftinstalled.- A local OCI images registry to push images to or access to a public one.
This is part of the Charmed Temporal Tutorial. Please refer to this page for more information and the overview of the content.
The Temporal worker is the entity that listens and polls a specific task queue, and executes code in response to the task.
The Temporal worker charm allows users to upload and automatically run custom worker scripts, independent of the chosen SDK. This is achieved by creating a rock with all runtime dependencies, worker scripts, and workflows, that is used at deployment time.
Because of this, deploying the worker involves three steps:
- Creating a custom container image for the worker using rocks.
- Deploying the worker charm using a custom container image.
- Integrating the worker with the Temporal server via the
temporal-host-inforelation.
This guide covers two deployment topologies:
- Same-model deployment (recommended for first-time users): worker runs in the same Juju model as the Temporal server.
- Cross-model deployment (production-style): worker runs in a dedicated Juju model for isolation, integrated to the server via a cross-model relation.
Each topology has its own walkthrough below. Pick the one that matches your environment and follow it through the Deploy and Connect sections.
If your worker runs against a Temporal server outside the Juju controller, an ingress can be considered. See Configure Ingress with Nginx Ingress Integrator for more details.
Custom container image for the worker
To create a custom container image for the worker, you need to build and publish it using Rockcraft. The steps below guide you through creating a rock-based image that includes your worker script and associated workflows.
Create a
rockcraftproject. You can use therockcraft.yamlas template. -
Ensure the
commandof the rock runs the worker script directly. For example, ifcommand: "/app/scripts/start-worker.sh":
$ cat start-worker.sh
python3 /app/resource_sample/worker.py
Ensure your activities and workflows are also included in the rock as the worker script needs access to them.
Build the rock with
rockcraft pack. -
Make your rock available in a local or public registry. See Publish a rock to a registry for details.
Deploy the Temporal worker
Once the rock is ready and available, deploy the worker charm. The exact commands depend on the topology you chose in the introduction.
Deploy the worker into the same Juju model as the Temporal server.
- Deploy the worker charm using the recently created image:
juju deploy temporal-worker-k8s --channel 2.0/stable --base ubuntu@24.04 \
--resource temporal-worker-image=<your-registry>/<your-rock-name>:<tag>
- Configure the worker with the task queue to poll and namespace to connect to:
juju config temporal-worker-k8s queue=your-queue namespace=your-namespace
The temporal-worker-k8s charm follows its own version track (2.0), independent of the Temporal server (1.31). User workflows are SDK-pinned rather than server-pinned, so the worker charm does not bump its track when the server bumps. 2.0/stable is the supported track for use with temporal-k8s 1.31/stable.
Deploy the worker into a dedicated Juju model.
A dedicated model gives logical isolation between the Temporal server components and the workers. This is useful for production environments where the worker fleet has its own access controls, scaling policy, or operator team.
- Add a model for the workers and deploy the charm there:
juju add-model temporal-workers-model
juju deploy temporal-worker-k8s -m temporal-workers-model \
juju config -m temporal-workers-model temporal-worker-k8s queue=your-queue namespace=your-namespace
At this point the worker is configured but does not yet know how to reach the Temporal frontend. The next section adds the temporal-host-info relation, which is the supported way to provide that information.
Connect the worker to the Temporal server using temporal-host-info
The worker discovers the Temporal frontend’s host and port through the temporal-host-info relation, provided by the temporal-k8s charm. This is the supported and recommended way to connect a worker to a Temporal server in 1.23/stable, 1.31/stable, and later.
Once the relation is in place, the worker re-reads the frontend address whenever the server publishes a change, with no manual reconfiguration required. If the relation is absent, the worker falls back to the deprecated host config. See the deprecation notice at the end of this section.
temporal-k8s provides two endpoints that implement the temporal-host-info interface. Choose one based on where the worker runs:
temporal-host-infopublishes the Temporal frontend’s Kubernetes cluster-internal DNS hostname (for exampletemporal-k8s.<model>.svc.cluster.local). Use it when the worker runs on the same Kubernetes cluster as the server, whether in the same model or a different one.temporal-external-host-infopublishes the hostname configured for the server’singressrelation, along with the ingress listener port and whether it serves TLS. Use it when the worker runs on a different Kubernetes cluster from the server, where the cluster-internal hostname cannot be resolved. See Different Kubernetes cluster.
Same-model integration
If the worker and the server are in the same Juju model, integrate them directly:
juju integrate temporal-k8s:temporal-host-info temporal-worker-k8s:temporal-host-info
Then wait for the worker to reach active:
juju wait-for application temporal-worker-k8s --query='status=="active"' --timeout=10m
juju status
Cross-model integration
If the worker lives in a separate model from the server on the same Kubernetes cluster, use a cross-model relation with the temporal-host-info endpoint. This involves three commands: juju offer on the server side, juju consume on the worker side, then juju integrate.
- In the server model (the model where
temporal-k8sis deployed), exposetemporal-host-infoas an offer:
juju switch <server-model>
juju offer temporal-k8s:temporal-host-info
This produces an offer URL of the form <controller>:admin/<server-model>.temporal-k8s.
- In the worker model, consume the offer and integrate the worker against it:
juju switch temporal-workers-model
juju consume <controller>:admin/<server-model>.temporal-k8s temporal-host-info-offer
juju integrate temporal-worker-k8s:temporal-host-info temporal-host-info-offer
- Wait for the worker to reach
active:
juju status
If the worker runs on a different Kubernetes cluster from the server, use the temporal-external-host-info endpoint. It requires the server to be exposed through ingress (see Configure ingress), publishes nothing until ingress is ready, and withdraws its data when ingress is removed.
- In the server model, offer the external endpoint:
juju offer temporal-k8s:temporal-external-host-info temporal-k8s-external
- In the worker model, consume the offer and integrate it with the worker’s
temporal-host-infoendpoint:
juju consume <controller>:admin/<server-model>.temporal-k8s-external
juju integrate temporal-worker-k8s:temporal-host-info temporal-k8s-external
- When the ingress serves TLS, set
tls-root-casto the CA that signed the ingress certificate; the host-info relation does not carry a CA:
juju config temporal-worker-k8s tls-root-cas="$(cat <ingress-ca>.pem)"
active:
juju status
The worker now polls the task queue and namespace you configured, against the frontend address advertised over the relation.
Deprecation notice:
hostconfigEarlier versions of the
temporal-worker-k8scharm accepted ahostconfig option to point at the Temporal server.hostis deprecated and will be removed in a future release. It is only consulted as a fallback when thetemporal-host-inforelation is absent.Do not introduce new dependencies on
host. If you are migrating an existing worker that useshost, integrate the relation as shown above and clear the config:juju config temporal-worker-k8s --reset host. See thelatest/stable→1.23/stableupgrade guide for the full migration procedure.
Expose worker metadata to other charms (optional)
The worker charm provides a temporal-worker-info relation that publishes its namespace and task queue to consuming charms. This lets downstream charms (for example, an admin or routing charm) discover where to start workflows without hard-coding the values.
If you are writing a charm that needs to consume worker metadata, use the temporal_worker_info charm library. The TemporalWorkerInfoRequirer class exposes an is_ready() method and a temporal_worker_info_available event.
Most tutorial users do not need this relation. It is only relevant if another Juju application needs to discover the worker’s namespace and queue.
See next: Run Your First Workflow
