Run Your First Workflow
This is part of the Charmed Temporal Tutorial. Please refer to this page for more information and the overview of the content.
Now that you have a Temporal Server up and running with a Temporal Worker connected to it, you will trigger a workflow execution and observe its result in the Web UI.
This tutorial uses the GreetingWorkflow workflow type registered by the
resource_sample_py
sample worker image. If you used a different worker image, substitute the matching
workflow type. Other workflow types registered by the sample image include
VaultWorkflow and DatabaseWorkflow.
You can trigger a workflow either via the Temporal Python SDK (option A) or via the
admin charm’s cli action (option B).
Option A: trigger via the Python SDK
- Create a client to trigger the workflow as defined in the worker. For instance, using the Canonical
temporal-lib-pywrapper:
from temporallib.client import Client, Options
import asyncio
async def main():
client_opt = Options(
host="temporal-k8s.<model>.svc.cluster.local:7233",
queue="your-queue",
namespace="your-namespace",
client = await Client.connect(client_opt=client_opt)
greeting = await client.execute_workflow(
"GreetingWorkflow",
"world", # workflow input (the name to greet)
id="hello-1",
task_queue="your-queue",
print(greeting)
if __name__ == "__main__":
asyncio.run(main())
Replace:
<model>with the Juju model name wheretemporal-k8sis deployed.your-queueandyour-namespacewith the values you set in the Deploy Temporal Admin and Deploy Temporal Worker steps.
- Install the necessary packages and run the script as follows:
pip install temporal-lib-py
python workflow.py
Option B: trigger via the admin charm’s cli action
If you do not want to write Python, the admin charm exposes a cli action that wraps the modern temporal CLI:
juju run temporal-admin-k8s/0 cli args="workflow start \
--type GreetingWorkflow \
--task-queue your-queue \
--workflow-id hello-1 \
--input '\"world\"' \
--namespace your-namespace" --wait 1m
Verify the result:
juju run temporal-admin-k8s/0 cli args="workflow show \
You should see the workflow’s full event history ending in WorkflowExecutionCompleted with status COMPLETED.
View the workflow in the Web UI
Further details on the workflow execution can be viewed on the
Temporal Web UI you deployed earlier. Look up the workflow by ID (hello-1 in the examples above) to see its event history, input, output, and timing.
Workflow and activity payloads can be encrypted by setting the same key in
the auth-secret-id config of the Temporal worker and the Client configurations
provided by the various Temporal SDKs.
See auth-secret-id for details.
If TLS termination on ingress is configured, you must also provide the Certificate Authority (CA) to the client. See Temporal SDKs for configuration details.
See next: Cleanup your environment
