Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your PostgreSQL application.
To summarize:
- Deploy the Tempo charm in a COS K8s environment
- Offer interfaces for cross-model integrations
- Consume and integratre cross-model integrations
- View PostgreSQL traces on Grafana
This feature is available for Charmed PostgreSQL revision 421+ only.
- Have deployed a Charmed PostgreSQL application
- Have deployed a ‘cos-lite’ bundle from the
latest/edgetrack in a Kubernetes environment
Deploy Tempo
Then, deploy the dependencies of Tempo following this tutorial. In particular, we would want to:
- Deploy the minio charm
- Deploy the s3 integrator charm
- Add a bucket into minio using a python script
- Configure s3 integrator with the minio credentials
Finally, deploy and integrate with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed PostgreSQL is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed PostgreSQL model, find the offers, and integrate (relate) with them:
juju switch <machine_controller_name>:<postgresql_model_name>
Do not miss the “
:” in the command above.
Store URL Access Interfaces
k8s admin/cos.tempo admin tracing:tracing
juju consume k8s:admin/cos.tempo
Consume interfaces
First, deploy Grafana Agent from the latest/edge channel.
juju deploy grafana-agent --channel latest/edge
Then, integrate Grafana Agent with Charmed PostgreSQL:
juju integrate postgresql:cos-agent grafana-agent:cos-agent
Finally, integrate Grafana Agent with the consumed interface from the previous section:
juju integrate grafana-agent:tracing tempo:tracing
Wait until the model settles. The following is an example of the juju status --relations on the Charmed PostgreSQL model:
database lxd localhost/localhost 3.5.4 unsupported 21:43:34Z
SAAS Status Store URL
tempo active uk8s admin/cos.tempo
grafana-agent blocked 1 grafana-agent latest/edge 286 no Missing ['grafana-cloud-config']|['grafana-dashboards-provider']|['logging-consumer']|['send-remote-write'] for cos-a...
postgresql 14.13 active 1 postgresql 0 no
postgresql/0* active idle 0 10.205.193.87 5432/tcp Primary
grafana-agent/0* blocked idle 10.205.193.87 Missing ['grafana-cloud-config']|['grafana-dashboards-provider']|['logging-consumer']|['send-remote-write'] for cos-a...
0 started 10.205.193.87 juju-1fee5d-0 ubuntu@22.04 Running
grafana-agent:peers grafana-agent:peers grafana_agent_replica peer
postgresql:cos-agent grafana-agent:cos-agent cos_agent subordinate
postgresql:database-peers postgresql:database-peers postgresql_peers peer
postgresql:restart postgresql:restart rolling_op peer
postgresql:upgrade postgresql:upgrade upgrade peer
tempo:tracing grafana-agent:tracing tracing regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select postgresql as the Service Name under the Search tab to view traces belonging to Charmed PostgreSQL.
Below is a screenshot demonstrating a Charmed PostgreSQL trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
