Note: All commands are written for juju >= v.3.1
How to enable TLS encryption
This guide will show how to enable TLS/SSL on a PostgreSQL cluster using the self-signed-certificates operator as an example.
This guide assumes everything is deployed within the same network and Juju model.
See also: How to deploy for external TLS access
- Enable TLS
- Disable TLS
- Check certificates in use
- Update keys
Enable TLS
Self-signed certificates are not recommended for a production environment.
Check this guide about X.509 certificates for an overview of all the TLS certificate charms available.
First, deploy the TLS charm:
To enable TLS integrate (formerly known as “relate”) the two applications:
juju integrate postgresql:certificates self-signed-certificates:certificates
To check the certificates in use by PostgreSQL, run
openssl s_client -starttls postgres -connect <leader_unit_IP>:<port> | grep issuer
Update keys
Updates to private keys for certificate signing requests (CSR) can be made via the set-tls-private-key action. Note that passing keys to external/internal keys should only be done with base64 -w0, not cat.
With three replicas, this schema should be followed:
Generate a shared internal key:
openssl genrsa -out internal-key.pem 3072
Generate external keys for each unit:
openssl genrsa -out external-key-0.pem 3072
openssl genrsa -out external-key-1.pem 3072
openssl genrsa -out external-key-2.pem 3072
Apply both private keys to each unit. The shared internal key will be applied only to the juju leader.
juju run postgresql/0 set-tls-private-key "external-key=$(base64 -w0 external-key-0.pem)" "internal-key=$(base64 -w0 internal-key.pem)" --wait
juju run postgresql/1 set-tls-private-key "external-key=$(base64 -w0 external-key-1.pem)" "internal-key=$(base64 -w0 internal-key.pem)" --wait
juju run postgresql/2 set-tls-private-key "external-key=$(base64 -w0 external-key-2.pem)" "internal-key=$(base64 -w0 internal-key.pem)" --wait
Updates can also be done with auto-generated keys:
Disable TLS
Disable TLS by removing the integration.
juju remove-relation postgresql:certificates self-signed-certificates:certificates
