Releases
This page provides high-level overviews of the dependencies and features that are supported by each revision in every stable release.
To learn more about the different release tracks and channels, see the Juju documentation about channels.
To see all releases and commits, check the Charmed PostgreSQL Releases on GitHub.
Dependencies and supported features
For a given release, this table shows:
- The PostgreSQL version packaged inside
- The minimum Juju version required to reliably operate all features of the release
This charm still supports older versions of Juju down to 2.9. See the system requirements for more details
- Support for specific features
| Revision | PostgreSQL version | Juju version | TLS encryption* | COS monitoring | Minor version upgrades | Cross-regional async replication | Point-in-time recovery | PITR Timelines |
| 494, 495 | 14.15 | 3.6.1+ |
| 462, 463 | 14.13 | 3.6.1+ |
| 444, 445 | 14.12 | 3.4.3+ |
| 381, 382 | 14.12 | 3.4.3+ |
| 280, 281 | 14.11 | 3.4.2+ |
| 193 | 14.10 | 3.4.2+ |
| 177 | 14.9 | 3.1.6+ |
| 158 | 14.9 | 3.1.5+ |
| 73 | 14.7 | 2.9.32+ |
TLS encryption*: Support for v2 or higher of the tls-certificates interface. This means that you can integrate with modern TLS charms.
For more details about a particular revision, refer to its dedicated Release Notes page. For more details about each feature/interface, refer to their dedicated How-To guide.
Architecture and base
Several revisions are released simultaneously for different bases/series using the same charm code. In other words, one release contains multiple revisions.
If you do not specify a revision on deploy time, Juju will automatically choose the revision that matches your base and architecture.
If you deploy a specific revision, you must make sure it matches your base and architecture via the tables below or with
juju info.
Release 494, 495
Older releases
Release 462, 463
Release 444-445
Release 381-382
Release 280-281
Release 193
| Revision | amd64 | arm64 | Ubuntu 22.04 LTS |
| 193 |
Release 177
| 177 |
Release 158
| 158 |
Release 73
| 73 |
Plugins/extensions
For a list of all plugins supported for each revision, see the reference page Plugins/extensions.
Note Our release notes are an ongoing work in progress. If there is any additional information about releases that you would like to see or suggestions for other improvements, don’t hesitate to contact us on Matrix or leave a comment.
