How to deploy
This page aims to provide an introduction to the PostgreSQL deployment process and lists all the related guides. It contains the following sections:
General deployment instructions
The basic requirements for deploying a charm are the Juju client and a machine cloud.
First, bootstrap the cloud controller and create a model:
juju bootstrap <cloud name> <controller name>
juju add-model <model name>
Then, either continue with the juju client or use the terraform juju client to deploy the PostgreSQL charm.
To deploy with the juju client:
juju deploy postgresql -n <number_of_replicas>
See also:
juju deploycommand
To deploy with terraform juju, follow the guide How to deploy using Terraform.
If you are not sure where to start or would like a more guided walkthrough for setting up your environment, see the Charmed PostgreSQL tutorial.
Clouds
The guides below go through the steps to install different cloud services and bootstrap them to Juju:
How to deploy on multiple availability zones (AZ) demonstrates how to deploy a cluster on a cloud using different AZs for high availability.
Special deployment scenarios
These guides cover some specific deployment scenarios and configurations.
Networking
How to deploy for external TLS VIP access goes over an example deployment of PostgreSQL, PgBouncer and HAcluster that require external TLS/SSL access via Virtual IP (VIP).
See also:
How to deploy on juju spaces goes over how to configure your deployment of PostgreSQL and client application to use juju spaces to separate network traffic.
Airgapped
How to deploy in an offline or air-gapped environment goes over the special configuration steps for installing PostgreSQL in an airgapped environment via CharmHub and the Snap Store Proxy.
Cluster-cluster replication
Cluster-cluster, cross-regional, or multi-server asynchronous replication focuses on disaster recovery by distributing data across different servers.
The Cross-regional async replication guide goes through the steps to set up clusters for cluster-cluster replication, integrate with a client, and remove or recover a failed cluster.
Juju storage
Charmed PostgreSQL uses the Juju storage abstraction to utilize data volume provided by different clouds while keeping the same UI/UX for end users.
See: How to deploy on juju storage
