Charmed PostgreSQL How-To | Deploy external TLS access
Deploy for external TLS VIP access
This guide goes over an example deployment of PostgreSQL, PgBouncer and HAcluster that require external TLS/SSL access via Virtual IP (VIP).
It combines the following guides, where you can find more detailed information:
Requirements
Although Canonical does not prescribe how you should set up your environment, we can provide recommendations. Consider contacting us for support with your use-case.
The basic requirements to follow along with this example setup are the following:
Design
This setup applicable for VM/machine charms only. Do NOT use it for K8s deployments!
This setup deploys the following components:
Deploy components
Create a Juju model if you haven’t already:
juju add-model my-external-tls-db
Deploy postgresql and self-signed-certificates:
juju deploy postgresql -n 3
juju integrate postgresql self-signed-certificates
Deploy pgbouncer from the 1/stable channel and configure it with your VIP:
juju deploy pgbouncer --channel 1/stable --config vip=10.20.30.40
juju integrate pgbouncer postgresql
juju integrate pgbouncer self-signed-certificates
Deploy data-integrator with 3 units and configure the database name of your choice. In this example, we use mytestdb:
juju deploy data-integrator -n 3 --config database-name=mytestdb
juju integrate data-integrator pgbouncer
Deploy hacluster:
juju deploy hacluster
juju integrate hacluster pgbouncer
juju integrate hacluster:juju-info data-integrator
Example juju status output:
Model               Controller  Cloud/Region         Version  SLA          Timestamp
my-external-tls-db  lxd         localhost/localhost  3.5.5    unsupported  12:53:35+01:00
App                       Version  Status  Scale  Charm                     Channel        Rev  Exposed  Message
data-integrator                    active      3  data-integrator           latest/stable   78  no
hacluster                 2.1.2    active      3  hacluster                 2.4/stable     131  no       Unit is ready and clustered
pgbouncer                 1.21.0   active      3  pgbouncer                 1/stable       396  no       VIP: 10.78.217.100
postgresql                14.12    active      3  postgresql                14/stable      468  no
self-signed-certificates           active      1  self-signed-certificates  latest/stable  155  no
Unit                         Workload  Agent  Machine  Public address  Ports     Message
data-integrator/0            active    idle   4        10.78.217.30
  hacluster/3                active    idle            10.78.217.30              Unit is ready and clustered
  pgbouncer/0*               active    idle            10.78.217.30    6432/tcp  VIP: 10.78.217.100
data-integrator/1            active    idle   5        10.78.217.132
  hacluster/2                active    idle            10.78.217.132             Unit is ready and clustered
  pgbouncer/1                active    idle            10.78.217.132   6432/tcp
data-integrator/2*           active    idle   6        10.78.217.93
  hacluster/1*               active    idle            10.78.217.93              Unit is ready and clustered
  pgbouncer/2                active    idle            10.78.217.93    6432/tcp
postgresql/0                 active    idle   0        10.78.217.254   5432/tcp
postgresql/1                 active    idle   1        10.78.217.245   5432/tcp
postgresql/2*                active    idle   2        10.78.217.192   5432/tcp  Primary
self-signed-certificates/0*  active    idle   3        10.78.217.79
Machine  State    Address        Inst id        Base          AZ  Message
0        started  10.78.217.254  juju-318984-0  ubuntu@22.04      Running
1        started  10.78.217.245  juju-318984-1  ubuntu@22.04      Running
2        started  10.78.217.192  juju-318984-2  ubuntu@22.04      Running
3        started  10.78.217.79   juju-318984-3  ubuntu@22.04      Running
4        started  10.78.217.30   juju-318984-4  ubuntu@22.04      Running
5        started  10.78.217.132  juju-318984-5  ubuntu@22.04      Running
6        started  10.78.217.93   juju-318984-6  ubuntu@22.04      Running
Check connectivity
To test the connection to PostgreSQL via TLS, first get the credentials via data-integrator:
postgresql:
  data: '{"database": "mytestdb", "external-node-connectivity": "true", "requested-secrets":
    "[\"username\", \"password\", \"tls\", \"tls-ca\", \"uris\"]"}'
  database: mytestdb
  endpoints: 10.78.217.100:6432
  password: V7kHqHyapIphkUS0cHoOtP3j
  subordinated: "true"
  uris: postgresql://relation_id_9:V7kHqHyapIphkUS0cHoOtP3j@10.78.217.100:6432/mytestdb
  username: relation_id_9
  version: "14.12"
Now use the received credentials (uris) to connect PostgreSQL (via TLS/SSL):
> psql postgresql://relation_id_9:V7kHqHyapIphkUS0cHoOtP3j@10.78.217.100:6432/mytestdb
psql (14.15 (Ubuntu 14.15-0ubuntu0.22.04.1), server 14.12 (Ubuntu 14.12-0ubuntu0.22.04.1))
SSL connection (protocol: TLSv1.3, cipher: TLS_AES_256_GCM_SHA384, bits: 256, compression: off)
Type "help" for help.
mytestdb=> select now();
              now
 2025-01-14 11:51:04.646245+00
(1 row)
Ensure your DNS records points to the virtual IP and that it is routable/reachable from outside of your network to connect using DNS:
psql postgresql://relation_id_9:V7kHqHyapIphkUS0cHoOtP3j@my-tls-example-db.local:6432/mytestdb
(Optional) Add monitoring
Consider adding the Canonical Observability Stack (COS) to your setup for monitoring, alert rules, logs, and tracing.
See: PostgreSQL | How to enable monitoring, PgBouncer | How to enable monitoring.
High availability
In production environments, deploy different units into separate availability zones (AZ).
See: How to deploy > Multi-AZ
At this point, Juju is responsible for the health of the clusters/applications:
  • The PostgreSQL charm will restart the workload if PostgreSQL is not healthy.
  • The Juju agent will restart the unit/vm/container if it is no longer reachable/healthy (in the same AZ).
  • The Juju controller will make sure Juju agent is up and running and charm is healthy.
  • The HACluster charm will make sure the VIP is always reachable and routes to a single PgBouncer.
  • PgBouncer will balance incoming connections and makes sure write traffic goes to the primary PostgreSQL unit.
  • The TLS operator (in this example, the self-signed-certificates charm) is responsible for providing all components with signed ready-to-use TLS artifacts.
Troubleshooting
Contact us if you have any issues with this setup or would like help with a different use-case.
