Manage Passwords
Passwords
When we accessed OpenSearch earlier in this tutorial, we needed to include a password in the HTTP request. Over time it is a good practice to change the password frequently. Here we will go through setting and changing the password for the admin user.
Retrieve the admin password
As previously mentioned, the admin credentials (password + the ca chain used to generate the admin client certificate) can be retrieved by running the get-password
action on the Charmed OpenSearch application:
juju run-action opensearch/leader get-password --wait
unit-opensearch-0:
UnitId: opensearch/0
results:
ca-chain: |-
<certificate>
password: <password>
username: admin
status: completed
timing:
completed: 2023-04-06 11:36:41 +0000 UTC
enqueued: 2023-04-06 11:36:20 +0000 UTC
started: 2023-04-06 11:36:36 +0000 UTC
The admin password is under the result: admin-password
Rotate the admin password
You can change the admin password to a new random and generated password by running:
juju run-action opensearch/leader set-password --wait
Note: this action can only be run from the leader unit.
unit-opensearch-0:
results:
admin-password: n4E4z3Dk19irKJPeZU27B24l1wKoA2sP
status: completed
timing:
completed: 2023-04-06 11:38:22 +0000 UTC
enqueued: 2023-04-06 11:38:17 +0000 UTC
started: 2023-04-06 11:38:20 +0000 UTC
. It should be different from your previous password.
You can test this password works correctly using the same HTTP requests you used during Section 5: Connecting to OpenSearch
Set the admin password
You can change the admin password to a specific password by entering:
juju run-action opensearch/leader set-password password=<password> --wait
unit-opensearch-0:
results:
admin-password: <password>
status: completed
timing:
completed: 2023-04-06 11:39:41 +0000 UTC
enqueued: 2023-04-06 11:39:38 +0000 UTC
started: 2023-04-06 11:39:40 +0000 UTC
The admin password under the result: admin-password
should match whatever you passed in when you entered the command.
Set TLS Private Key
TLS private keys are used for certificate signing requests, and should be recycled in the same way as passwords. There are three types of private keys available to be updated on this charm, and they are as follows:
"app-admin"
is the key used for requesting a certificate with a CSR for the admin user and cluster administration related operations.- Must only be set on the leader unit.
"unit-transport"
is the key used for requesting, for the target unit, a certificate with a CSR for the transport layer (node to node communication). -
"unit-http"
is the key used for requesting, for the target unit, a certificate with a CSR for the admin user and cluster administration related operations.
To change a private key to a random value, run the following command, setting category
equal to your preferred type of private key:
juju run-action opensearch/leader set-tls-private-key category=<category> --wait
unit-opensearch-0:
results: {}
status: completed
timing:
completed: 2023-04-06 11:45:32 +0000 UTC
enqueued: 2023-04-06 11:45:29 +0000 UTC
started: 2023-04-06 11:45:30 +0000 UTC
No certificate data is presented in the results of this action.
To set the key to a specific value run the following command:
juju run-action opensearch/leader set-tls-private-key category=<category> key=<key> --wait
unit-opensearch-0:
results: {}
status: completed
timing:
completed: 2023-04-06 12:07:02 +0000 UTC
enqueued: 2023-04-06 12:07:01 +0000 UTC
started: 2023-04-06 12:07:01 +0000 UTC
If the key you intend to set has a passphrase, set it like so
juju run-action opensearch/leader set-tls-private-key category=<category> password=<password> key=<key> --wait
unit-opensearch-0:
results: {}
status: completed
timing:
completed: 2023-04-06 12:37:55 +0000 UTC
enqueued: 2023-04-06 12:37:52 +0000 UTC
started: 2023-04-06 12:37:54 +0000 UTC
Next Steps
The next stage in this tutorial is about horizontally scaling the OpenSearch cluster, and can be found here.
