How to safely scale-down
Horizontal scale down (removal of units) is a common process that administrators occasionally do, but one that requires special care in order to prevent data loss and keep the deployment of the application highly available.
(for more details on how to horizontally scale down / up please refer to this page)
Note: Do not remove multiple units at the same time. You should only remove one unit at a time to be able to control and react to the health of your cluster.
Though we implement rolling units removal, the internal state of OpenSearch is only reflected reactively, meaning the charm does not know beforehand whether a certain removal will put the cluster in a red
(some primary shards are unassigned) or yellow
(some replica shards are unassigned) – (you can read more about the cluster health in the OpenSearch official documentation).
Steps to follow when scaling down:
Here we detail the steps that an administrator must follow in order to guarantee the safety of the process:
1. Before scaling down:
You should make sure that removing nodes is a safe operation to do. For that, check the health of the cluster: the charm will usually reflect the current health of the cluster on the application status, i.e:
tutorial opensearch-demo localhost/localhost 2.9.42 unsupported 15:46:15Z
data-integrator active 1 data-integrator edge 11 no
opensearch blocked 2 opensearch edge 22 no 1 or more 'replica' shards are not assigned, please scale your application up.
tls-certificates-operator active 1 tls-certificates-operator stable 22 no
You can also manually verify it by using the OpenSearch health api.
Reminder: in order to authenticate your requests to the REST API, you need to retrieve the admin user’s credentials. You can run the following command:
juju run-action opensearch/leader get-password --wait
> unit-opensearch-0:
results:
ca-chain: |-
<certificate>
username: admin
password: admin_password
If the cluster health is:
green
: the scale down may be safe to do: it is imperative to check whether the node targeted for removal does not hold a primary shard of an index with no replicas! You can see this by making the following request and seeing which primary shards are allocated to the said node.curl -k -XGET https://admin:admin_pasword@10.180.162.96:9200/_cat/shards
It is in general a bad idea to disable replication for indices, but if that’s the case: please re-route the said shard manually to another node.
yellow
: scaling down may not be a good idea. This means that some replica shards areunassigned
- you can visualize that by using the cat api. i.e:curl -k -XGET https://10.180.162.96:9200/_cat/shards -u admin:admin_password
A general good course of action here would be the opposite, to scale up / add a unit to have a
green
state where all primary and replica shards are well assigned.Regardless, you should investigate why is your cluster in a
yellow
state. You can make the following call to have an explanation:curl -k -XGET "https://10.180.162.96:9200/_cluster/allocation/explain?filter_path=index,shard,primary,**.node_name,**.node_decision,**.decider,**.decision,**.*explanation,**.unassigned_info,**.*delay" -u admin:admin_password
And react accordingly, such as horizontally scaling up or adding more storage to the existing nodes or perhaps manually re-route the said shard manually to another node.
red
: scaling down is definitely not a good idea, as some primary shards are not assigned. The course of action to follow here would be to add units to the cluster.
Note: You’ll notice we did not use the certificates to authenticate the curl requests above, in a real world example you should always make sure you verify your requests with the TLS certificates received from the get-password
action.
i.e:
curl --cacert cert.pem -XGET https://admin:admin_password@10.180.162.96:9200/_cluster/health
2. Scaling down / remove unit:
Now that you made sure that removing a unit may be safe to do. ONLY remove 1 unit at a time.
You can run the following command (change the unit name to the one you’re targeting):
juju remove-unit opensearch/2
Make sure you monitor the status of the application using: watch -c juju status --color
3. After scale down:
After removing a unit, depending on the roles of the said unit, the charm may reconfigure and restart a unit to balance the node roles. (you should see this by monitoring the juju status: watch -c juju status --color
Please make sure you wait for all the application to stabilize, before you consider removing further units.
Now, you should check the health of the cluster as detailed previously and react accordingly.
Note: If after a scale down the health color is red: the charm will attempt to block the removal of the node, giving the administrator the opportunity to scale up / add units.
