Charmed MySQL Reference | Charm statuses
Charm statuses
This is an work-in-progress article. Do not use it in production! Contact Canonical Data Platform team if you are interested in the topic.
The charm follows standard Juju applications statuses. Here you can find the expected end-users reaction on different statuses:
Juju Status Message Expectations Actions
active any Normal charm operations No actions required
waiting any Charm is waiting for relations to be finished No actions required
maintenance any Charm is performing the internal maintenance (e.g. cluster re-configuration) No actions required
blocked any The manual user activity is required! Follow the message hints (see below)
blocked Failed to set up relation The relation between two applications failed to be created. Most probably it is a regression of the recent changes in applications Check Juju debug-log. Increase debug level and reproduce the issue. Report as an issue with debug logs attached (if reproducible). Consider to try previous revision for both applications
blocked Failed to initialize mysql relation The same as “Failed to set up relation” See “Failed to set up relation”
blocked Failed to remove relation user TODO: clean manually? How to unblock?
blocked Failed to install and configure MySQL TODO
blocked Failed to initialize MySQL users TODO
blocked Failed to configure instance for InnoDB TODO
blocked Failed to create custom mysqld config TODO
blocked Failed to connect to MySQL exporter TODO
blocked Failed to create the InnoDB cluster TODO
blocked Failed to initialize juju units operations table TODO
blocked failed to recover cluster. TODO
blocked Failed to initialize shared_db relation Try to remove and add relations. Report as an issue (with debug logs) if reproducible
blocked Failed to create app user or scoped database TODO
blocked Failed to delete users for departing unit TODO
blocked Failed to set TLS configuration Problems with TLS certifications generation Remove and add relations with TLS operator. Report as an issue (with debug logs) if reproducible
blocked Failed to restore default TLS configuration TODO
blocked Failed to create backup; instance in bad state TODO
blocked Failed to re-initialize MySQL data-dir TODO
blocked Failed to re-initialize MySQL users TODO
blocked Failed to re-configure instance for InnoDB TODO
blocked Failed to purge data dir TODO
blocked Failed to reset root password TODO
error any An unhanded internal error happened Read the message hint. Execute juju resolve <error_unit/0> after addressing the root of the error state
terminated any The unit is gone and will be cleaned by Juju soon No actions possible
unknown any Juju doesn’t know the charm app/unit status. Possible reason: K8s charm termination in progress. Manual investigation required if status is permanent
