Troubleshooting
WARNING: at the moment, there is NO ability to pause operator!
Make sure your activity will not interfere with the operator itself!
Ensure you went into the real issue which requires the manual activity. Run juju status and check the list of charm statuses and recommended activities there.
Logs
Please be familiar with Juju logs concepts and learn how to manage Juju logs.
Always check the Juju logs before troubleshooting further:
juju debug-log --replay --tail
Focus on ERRORS (normally there should be none):
juju debug-log --replay | grep -c ERROR
Consider to enable DEBUG log level IF you are troubleshooting wired charm behavior:
juju model-config 'logging-config=<root>=INFO;unit=DEBUG'
The MySQL logs are located inside SNAP:
> ls -la /var/snap/charmed-mysql/common/var/log/*
/var/snap/charmed-mysql/common/var/log/mysql:
-rw-r----- 1 snap_daemon root 8021 Sep 18 22:05 error.log
/var/snap/charmed-mysql/common/var/log/mysqlsh:
-rw------- 1 snap_daemon snap_daemon 12516 Sep 18 22:05 mysqlsh.log
/var/snap/charmed-mysql/common/var/log/mysqlrouter:
# The MySQL Router should be stopped on Charmed MySQL deployments and produce no logs.
SNAP-based Charm
Check the operator architecture first to be familiar with SNAP content, operator building blocks and running Juju units.
To enter the unit, use:
juju ssh mysql/0 bash
Make sure the SNAP charmed-mysql if installed and functional:
ubuntu@juju-6692b6-0:~$ sudo snap list charmed-mysql
Name Version Rev Tracking Publisher Notes
charmed-mysql 8.0.34 69 latest/stable dataplatformbot held
From here you can make sure all snap (systemd) services are running:
ubuntu@juju-6692b6-0# sudo snap services
Service Startup Current Notes
charmed-mysql.mysqld enabled active -
charmed-mysql.mysqld-exporter disabled inactive -
charmed-mysql.mysqlrouter-service disabled inactive -
ubuntu@juju-6692b6-0:~$ systemctl --failed
0 loaded units listed.
ubuntu@juju-6692b6-0:~$ ps auxww
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 167432 12588 ? Ss 22:04 0:02 /lib/systemd/systemd --system --deserialize 26
root 107 0.0 0.0 4744 1828 ? Ss 22:04 0:00 snapfuse /var/lib/snapd/snaps/core20_2015.snap /snap/core20/2015 -o ro,nodev,allow_other,suid
root 109 0.0 0.0 4800 1616 ? Ss 22:04 0:00 snapfuse /var/lib/snapd/snaps/lxd_24322.snap /snap/lxd/24322 -o ro,nodev,allow_other,suid
root 110 0.0 0.0 4724 1624 ? Ss 22:04 0:02 snapfuse /var/lib/snapd/snaps/snapd_19993.snap /snap/snapd/19993 -o ro,nodev,allow_other,suid
root 223 0.0 0.0 7284 2756 ? Ss 22:04 0:00 /usr/sbin/cron -f -P
message+ 225 0.0 0.0 8848 5276 ? Ss 22:04 0:00 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root 229 0.0 0.0 33084 18940 ? Ss 22:04 0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
syslog 230 0.0 0.0 152764 5124 ? Ssl 22:04 0:00 /usr/sbin/rsyslogd -n -iNONE
root 231 0.0 0.1 2133020 33096 ? Ssl 22:04 0:03 /usr/lib/snapd/snapd
root 233 0.0 0.0 15504 7424 ? Ss 22:04 0:00 /lib/systemd/systemd-logind
root 248 0.0 0.0 6216 1104 pts/0 Ss+ 22:04 0:00 /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 vt220
root 259 0.0 0.0 110084 21948 ? Ssl 22:04 0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
root 261 0.0 0.0 235556 8576 ? Ssl 22:04 0:00 /usr/libexec/polkitd --no-debug
root 1190 0.0 0.0 295960 20720 ? Ssl 22:04 0:00 /usr/libexec/packagekitd
systemd+ 1812 0.0 0.0 16116 6516 ? Ss 22:04 0:00 /lib/systemd/systemd-networkd
systemd+ 1817 0.0 0.0 25528 12740 ? Ss 22:04 0:00 /lib/systemd/systemd-resolved
root 1819 0.0 0.0 39780 20080 ? Ss 22:04 0:00 /lib/systemd/systemd-journald
root 2484 0.0 0.0 11088 5848 ? Ss 22:04 0:00 /lib/systemd/systemd-udevd
root 2817 0.0 0.0 15420 9284 ? Ss 22:04 0:00 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
root 3451 0.0 0.0 7760 3472 ? Ss 22:04 0:00 bash /etc/systemd/system/jujud-machine-1-exec-start.sh
root 3456 0.0 0.3 895284 103224 ? Sl 22:04 0:08 /var/lib/juju/tools/machine-1/jujud machine --data-dir /var/lib/juju --machine-id 1 --debug
root 3860 0.0 0.0 4772 1756 ? Ss 22:04 0:01 snapfuse /var/lib/snapd/snaps/core22_864.snap /snap/core22/864 -o ro,nodev,allow_other,suid
root 4036 0.0 0.0 4988 1764 ? Ss 22:04 0:03 snapfuse /var/lib/snapd/snaps/charmed-mysql_69.snap /snap/charmed-mysql/69 -o ro,nodev,allow_other,suid
snap_da+ 4830 0.0 0.0 2888 1820 ? Ss 22:05 0:00 /bin/sh /snap/charmed-mysql/69/usr/bin/mysqld_safe --defaults-file=/var/snap/charmed-mysql/69/etc/mysql/mysql.cnf
snap_da+ 5313 0.0 7.2 29251092 2394896 ? Sl 22:05 0:07 /snap/charmed-mysql/69/usr/sbin/mysqld --defaults-file=/var/snap/charmed-mysql/69/etc/mysql/mysql.cnf --basedir=/snap/charmed-mysql/69/usr --datadir=/var/snap/charmed-mysql/common/var/lib/mysql --plugin-dir=/snap/charmed-mysql/69/usr/lib/mysql/plugin --log-error=/var/snap/charmed-mysql/common/var/log/mysql/error.log --pid-file=/var/snap/charmed-mysql/common/var/run/mysqld/mysqld.pid --socket=/var/snap/charmed-mysql/common/var/run/mysqld/mysqld.sock
root 5690 0.0 0.0 34128 23904 ? S 22:05 0:00 /usr/bin/python3 src/ip_address_observer.py /usr/bin/juju-run mysql/1 /var/lib/juju/agents/unit-mysql-1/charm
ubuntu 5975 0.0 0.0 16924 9484 ? Ss 22:05 0:00 /lib/systemd/systemd --user
ubuntu 5976 0.0 0.0 170216 4804 ? S 22:05 0:00 (sd-pam)
root 6131 0.0 0.0 16916 10988 ? Ss 22:07 0:00 sshd: ubuntu [priv]
ubuntu 6177 0.0 0.0 17216 7980 ? R 22:07 0:00 sshd: ubuntu@pts/1
ubuntu 6178 0.0 0.0 9060 5204 pts/1 Ss 22:07 0:00 bash
ubuntu 6244 0.0 0.0 10460 3312 pts/1 R+ 22:08 0:00 ps auxww
The list of running SNAP/Systemd services will depends on configured (enabled) COS integration and/or Backup functionality. The SNAP service charmed-mysql.mysqld must always be active and currently running (the Linux processes snapd, mysqld_safe and mysqld).
To connect inside the MySQL, check the charm users concept and request root credentials to use mysql:
> juju run mysql/leader get-password username=root
password: I6ToMBOJKEPKwQG5wwUpuCcg
username: root
> > mysql -h 127.0.0.1 -u root -pI6ToMBOJKEPKwQG5wwUpuCcg mysql -e "show databases"
> | Database |
> | information_schema |
> | mysql |
> | mysql_innodb_cluster_metadata |
> | performance_schema |
> | sys |
Continue troubleshooting your DB/SQL related issues from here.
WARNING: please do NOT manage users, credentials, databases, schema directly to avoid a split bran situation with the operator and/or related (integrated) applications.
It is NOT recommended to restart services directly as it might create a split brain situation with operator internal state. If you see the problem with a unit, consider to remove failing unit and add-new-unit to recover the cluster state.
As a last resort, contact us If you cannot determinate the source of your issue. Also, feel free to improve this document!
Installing extra software:
WARNING: please do NOT install any additionally software as it may affect the stability and produce anomalies which is hard to troubleshoot and fix! Otherwise always remove manually installed components at the end of troubleshooting. Keep the house clean!
Sometimes it is necessary to install some extra troubleshooting software. Use the common approach:
ubuntu@juju-6692b6-0:~$ sudo apt update && sudo apt install gdb
Setting up gdb (12.1-0ubuntu1~22.04) ...
