Perform a minor upgrade
Example: MySQL 8.0.33 → MySQL 8.0.34
(including charm revision bump: e.g. Revision 193 → Revision 196)
This is part of the Upgrade section. Refer to the landing page for more information and an overview of the content.
Important information
We strongly recommend to NOT perform any other extraordinary operations on a Charmed MySQL cluster while upgrading. These may be (but not limited to) the following:
- Adding or removing units
- Creating or destroying new relations
- Changes in workload configuration
- Upgrading other connected/related/integrated applications simultaneously
Concurrency with other operations is not supported, and it can lead the cluster into inconsistent states.
Make sure to have a backup of your data when running any type of upgrades! See: How to create a backup
It is recommended to deploy your application in conjunction with Charmed MySQL Router. This will ensure minimal service disruption, if any.
Summary of the upgrade steps
- Collect all necessary pre-upgrade information. It will be necessary for the rollback (if requested). Do not skip this step!
- Prepare the Charmed MySQL application for the in-place upgrade
- Upgrade. Once started all units in a cluster will be executed sequentially. The upgrade will be aborted (paused) if the unit upgrade has failed.
- Consider a rollback in case of disaster. Please inform and include us in your case scenario troubleshooting to trace the source of the issue and prevent it in the future. Contact us!
- Post-upgrade check. Make sure all units are in a healthy state.
Step 1: Collect
This step is only valid when deploying from charmhub.
If a local charm is deployed (revision is small, e.g. 0-10), make sure the proper/current local revision of the .charm file is available BEFORE going further. You might need it for a rollback.
The first step is to record the revision of the running application as a safety measure for a rollback action. To accomplish this, run the juju status command and look for the deployed Charmed MySQL revision in the command output, e.g:
default vmc localhost/localhost 2.9.44 unsupported 17:58:37Z
mysql 8.0.33-0ubun... active 3 mysql 182 no
mysql/9 active idle 13 10.169.158.70 3306/tcp,33060/tcp
mysql/10* active idle 11 10.169.158.14 3306/tcp,33060/tcp Primary
mysql/11 active idle 12 10.169.158.217 3306/tcp,33060/tcp
11 started 10.169.158.14 juju-b72e25-11 jammy Running
12 started 10.169.158.217 juju-b72e25-12 jammy Running
13 started 10.169.158.70 juju-b72e25-13 jammy Running
For this example, the current revision is 182. Store it safely to use in case of rollback!
Step 2: Prepare
Before running the juju refresh command, it’s necessary to run the pre-upgrade-check action against the leader unit:
juju run mysql/leader pre-upgrade-check
The output of the action should look like:
unit-mysql-10:
results: {}
status: completed
The action will configure the charm to minimize the amount of primary switchover, among other preparations for a safe upgrade process. After successful execution, the charm is ready to be upgraded.
Step 3: Upgrade
Use the juju refresh command to trigger the charm upgrade process.
Example with channel selection
juju refresh mysql --channel 8.0/edge
Example with specific revision selection
juju refresh mysql --revision=183
Example with a local charm file
juju refresh mysql --path ./mysql_ubuntu-22.04-amd64.charm
All units are going to be refreshed (i.e. receive new charm content), and the upgrade will execute one unit at the time.
juju status will look like similar to the output below:
default vmc localhost/localhost 2.9.44 unsupported 18:10:30Z
mysql 8.0.33-0ubun... active 3 mysql 7 no
mysql/9 waiting idle 13 10.169.158.70 3306/tcp,33060/tcp other units upgrading first...
mysql/10* waiting idle 11 10.169.158.14 3306/tcp,33060/tcp other units upgrading first...
mysql/11 maintenance executing 12 10.169.158.217 3306/tcp,33060/tcp stopping services..
After each unit completes the upgrade, the message upgrade completed is displayed, and the next unit follows.
Example juju status during an upgrade:
default vmc localhost/localhost 2.9.44 unsupported 18:11:21Z
mysql/9 maintenance executing 13 10.169.158.70 3306/tcp,33060/tcp upgrading snap...
mysql/11 maintenance idle 12 10.169.158.217 3306/tcp,33060/tcp upgrade completed
Do NOT trigger rollback procedure during the running upgrade procedure.
It is expected to have some status changes during the process: waiting, maintenance, active.
Make sure upgrade has failed/stopped and cannot be fixed/continued before triggering rollback!
Please be patient during huge installations. Each unit should recover shortly after the upgrade, but time can vary depending on the amount of data written to the cluster while the unit was not part of it.
Incompatible charm revisions or dependencies will halt the process.
After a juju refresh, if there are any version incompatibilities in charm revisions, its dependencies, or any other unexpected failure in the upgrade process, the upgrade process will be halted and enter a failure state.
Step 4: Rollback (optional)
The step must be skipped if the upgrade went well!
If there was an issue with the upgrade, even if the underlying MySQL cluster continues to work, it’s important to roll back the charm to the previous revision. That way, the update can be attempted again after a further inspection of the failure.
Step 5: Check
Future improvements are planned to check the state of a cluster on a low level.
For now, use juju status to make sure the cluster state is OK.
