How to enable monitoring (COS)
Offer interfaces via the COS controller
Switch to COS K8s environment and offer COS interfaces to be cross-model related with Charmed MySQL K8s model.
To switch to the Kubernetes controller, for the cos model, run
juju switch <k8s_cos_controller>:<cos_model_name>
To offer the COS interfaces, run
juju offer grafana:grafana-dashboard
juju offer loki:logging
juju offer prometheus:receive-remote-write
Consume offers via the MySQL model
Next, we will switch to Charmed MySQL K8s model, find offers and consume them.
We are on the Kubernetes controller for the COS model. To switch to the MySQL model, run
juju switch <k8s_db_controller>:<mysql_model_name>
To find offers, run the following command (make sure not to miss the “:” at the end!):
juju find-offers <k8s_cos_controller>:
A similar output should appear, if k8s is the k8s controller name and cos the model where cos-lite has been deployed:
Store URL Access Interfaces
k8s admin/cos:grafana admin grafana:grafana-dashboard
k8s admin/cos.loki admin loki:logging
k8s admin/cos.prometheus admin prometheus:receive-remote-write
Consume offers to be reachable in the current model:
juju consume k8s:admin/cos.grafana
juju consume k8s:admin/cos.loki
juju consume k8s:admin/cos.prometheus
Deploy and integrate Grafana
First, deploy grafana-agent-k8s:
juju deploy grafana-agent-k8s --trust
Then, integrate (relate) it with Charmed MySQL K8s:
juju relate grafana-agent-k8s grafana
juju relate grafana-agent-k8s loki
juju relate grafana-agent-k8s prometheus
Finally, integrate (relate) grafana-agent-k8s with consumed COS offers:
juju relate grafana-agent-k8s mysql-k8s:grafana-dashboard
juju relate grafana-agent-k8s mysql-k8s:logging
juju relate grafana-agent-k8s mysql-k8s:metrics-endpoint
After this is complete, Grafana will show the new dashboards: MySQL Exporter and allows access for Charmed MySQL logs on Loki.
Sample outputs
The example of juju status on Charmed MySQL K8s model:
mysql charmed-dev microk8s/localhost 3.1.6 unsupported 02:20:09+02:00
SAAS Status Store URL
grafana active charmed-dev admin/cos.grafana
loki active charmed-dev admin/cos.loki
prometheus active charmed-dev admin/cos.prometheus
mysql-k8s 8.0.32-0ubuntu0.22.04.2 active 1 mysql-k8s 8.0/stable 61 10.152.183.115 no Primary
mysql-k8s/0* active idle 10.1.84.116 Primary
The example of juju status on COS K8s model:
cos charmed-dev microk8s/localhost 3.1.6 unsupported 02:20:11+02:00
alertmanager 0.23.0 active 1 alertmanager-k8s stable 47 10.152.183.206 no
catalogue active 1 catalogue-k8s stable 13 10.152.183.183 no
grafana 9.2.1 active 1 grafana-k8s stable 64 10.152.183.140 no
loki 2.4.1 active 1 loki-k8s stable 60 10.152.183.241 no
prometheus 2.33.5 active 1 prometheus-k8s stable 103 10.152.183.240 no
traefik 2.9.6 active 1 traefik-k8s stable 110 10.76.203.178 no
alertmanager/0* active idle 10.1.84.125
catalogue/0* active idle 10.1.84.127
grafana/0* active idle 10.1.84.83
loki/0* active idle 10.1.84.79
prometheus/0* active idle 10.1.84.96
traefik/0* active idle 10.1.84.119
Offer Application Charm Rev Connected Endpoint Interface Role
grafana grafana grafana-k8s 64 1/1 grafana-dashboard grafana_dashboard requirer
loki loki loki-k8s 60 1/1 logging loki_push_api provider
prometheus prometheus prometheus-k8s 103 1/1 receive-remote-write prometheus_scrape requirer
Connect Grafana web interface
To connect Grafana web interface, follow the COS section “Browse dashboards”:
juju run grafana/leader get-admin-password --model <k8s_controller>:<cos_model_name>
