Release Notes
This page provides high-level overviews of the dependencies and features that are supported by each revision in every stable release.
To learn more about the different release tracks and channels, see the Juju documentation about channels.
To see all releases and commits, check the Charmed MySQL K8s Releases page on GitHub.
| Release | MySQL version | Juju version | TLS encryption* | COS monitoring | Minor version upgrades | Cross-regional async replication | Point-in-time recovery |
| 254, 255 | 8.0.41 | 3.5.4+ |
| 240, 241 | 8.0.41 | 3.5.4+ |
| 210, 211 | 8.0.39 | 3.5.4+ |
| 180, 181 | 8.0.37 | 3.4.3+ |
| 153 | 8.0.36 | 3.4.3+ |
| 127 | 8.0.35 | 3.1.6+ |
| 113 | 8.0.34 | 3.1.6+ |
| 99 | 8.0.34 | 3.1.6+ |
| 75 | 8.0.32 | 2.9.32+ |
* TLS encryption: Support for v2 or higher of the tls-certificates interface. This means that you can integrate with modern TLS charms.
For more details about a particular revision, refer to its dedicated Release Notes page. For more details about each feature/interface, refer to the documentation linked in the column headers.
Architecture and base
Several revisions are released simultaneously for different bases/series using the same charm code. In other words, one release contains multiple revisions.
If you do not specify a revision on deploy time, Juju will automatically choose the revision that matches your base and architecture.
Release 254-255
Older releases
Release 240-241
Release 210-211
Release 180-181
Release 153
| Revision | amd64 | arm64 | Ubuntu 22.04 LTS |
| 153 |
Release 127
| 127 |
Release 113
| 113 |
Release 99
| 99 |
Release 75
| 75 |
