Reference
Technical specifications, APIs, release notes, and other reference material for fast lookup.
| Page | Description |
| Releases | Overview of all Charmed MySQL K8s releases |
| System requirements | Software and hardware requirements |
| Software testing | Software tests performed on this charm |
| Profiles | Configurations related to performance |
| Plugins/extensions | Supported plugins/extensions |
| Alert rules | Pre-configured Prometheus alert rules |
| Charm statuses | Juju application statuses |
| Contacts | Contact information |
In the tabs at the top of this charm’s CharmHub page, you will find the following automatically generated references:
| Integrations | Integration/relation interfaces supported by this charm |
| Configuration | Configuration parameters specific to this charm |
| Actions | Juju actions supported by this charm |
