Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your MySQL application.
To summarize:
- Deploy the Tempo charm in a COS K8s environment
- Offer interfaces for cross-model integrations
- Consume and integrate cross-model integrations
- View MySQL traces on Grafana
This feature is available for Charmed MySQL revision 237+ only.
- Have deployed a Charmed MySQL application
- Have deployed a ‘cos-lite’ bundle in a Kubernetes environment
Deploy Tempo
Then, deploy the dependencies of Tempo following this tutorial. In particular, we would want to:
- Deploy the minio charm
- Deploy the s3 integrator charm
- Add a bucket in minio using a python script
- Configure s3 integrator with the minio credentials
Finally, deploy and integrate with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed MySQL is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed MySQL VM model, find the offers, and integrate (relate) with them:
juju switch <machine_controller_name>:<mysql_model_name>
Do not miss the “
:” in the command above.
Store URL Access Interfaces
k8s admin/cos.tempo admin tracing:tracing
juju consume k8s:admin/cos.tempo
Consume interfaces
First, deploy Grafana Agent from the 1/stable channel:
juju deploy grafana-agent --channel 1/stable
Then, integrate Grafana Agent with Charmed MySQL:
juju integrate mysql:cos-agent grafana-agent:cos-agent
Finally, integrate Grafana Agent with the consumed interface from the previous section:
juju integrate grafana-agent:tracing tempo:tracing
Wait until the model settles. The following is an example of the juju status --relations on the Charmed MySQL model:
database lxd localhost/localhost 3.5.4 unsupported 19:15:55Z
SAAS Status Store URL
tempo active k8s admin/cos.tempo
grafana-agent blocked 1 grafana-agent 1/stable 452 no Missing ['grafana-cloud-config']|['grafana-dashboards-provider']|['logging-consumer']|['send-remote-write'] for cos-a...
mysql 8.0.37-0ubun... active 1 mysql 0 no
mysql/0* active idle 0 10.205.193.32 3306,33060/tcp Primary
grafana-agent/0* blocked idle 10.205.193.32 Missing ['grafana-cloud-config']|['grafana-dashboards-provider']|['logging-consumer']|['send-remote-write'] for cos-a...
0 started 10.205.193.32 juju-4f3e50-0 ubuntu@22.04 Running
grafana-agent:peers grafana-agent:peers grafana_agent_replica peer
mysql:cos-agent grafana-agent:cos-agent cos_agent subordinate
mysql:database-peers mysql:database-peers mysql_peers peer
mysql:restart mysql:restart rolling_op peer
mysql:upgrade mysql:upgrade upgrade peer
tempo:tracing grafana-agent:tracing tracing regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select mysql as the Service Name under the Search tab to view traces belonging to Charmed MySQL.
Below is a screenshot demonstrating a Charmed MySQL trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
