Storage > Storage provider
See also: How to manage storage
In Juju, a storage provider refers to the technology used to make storage available to a charm.
Contents:
Generic storage providers
There are several cloud-independent storage providers, which are available to all types of models:
loop
See also: Wikipedia | Loop device
- Block-type, creates a file on the unit’s root filesystem, associates a loop device with it. The loop device is provided to the charm.
rootfs
See also: The Linux Kernel Archives | ramfs, rootfs and initramfs
- Filesystem-type, creates a sub-directory on the unit’s root filesystem for the unit/charmed operator to use. Works with Kubernetes models.
tmpfs
See also: Wikipedia | Tmpfs
- Filesystem-type, creates a temporary file storage facility that appears as a mounted file system but is stored in volatile memory. Works with Kubernetes models.
Loop devices require extra configuration to be used within LXD. For that, please refer to Loop devices and LXD (below).
Cloud-specific storage providers
azure
Azure-based models have access to the ‘azure’ storage provider.
The ‘azure’ storage provider has an ‘account-type’ configuration option that accepts one of two values: ‘Standard_LRS’ and ‘Premium_LRS’. These are, respectively, associated with defined Juju pools ‘azure’ and ‘azure-premium’.
Newly-created models configured in this way use “Azure Managed Disks”. See Azure Managed Disks Overview for information on what this entails (in particular, what the difference is between standard and premium disk types).
cinder
OpenStack-based models have access to the ‘cinder’ storage provider.
The ‘cinder’ storage provider has a ‘volume-type’ configuration option whose value is the name of any volume type registered with Cinder.
ebs
AWS-based models have access to the ‘ebs’ storage provider, which supports the following pool attributes:
volume-type
Specifies the EBS volume type to create. You can use either the EBS volume type names, or synonyms defined by Juju (in parentheses):
- standard (magnetic)
- gp2 (ssd)
- gp3
- io1 (provisioned-iops)
- io2
- st1 (optimized-hdd)
- sc1 (cold-storage)
Juju’s default pool (also called ‘ebs’) uses gp2/ssd as its own default.
iops
- The number of IOPS for io1, io2 and gp3 volume types. There are restrictions on minimum and maximum IOPS, as a ratio of the size of volumes. See Provisioned IOPS (SSD) Volumes for more information.
encrypted
- Boolean (true|false); indicates whether created volumes are encrypted.
kms-key-id
- The KMS Key ARN used to encrypt the disk. Requires encrypted: true to function.
throughput
- The number of megabyte/s throughput a GP3 volume is provisioned for. Values are passed in the form 1000M or 1G etc.
For detailed information regarding EBS volume types, see the AWS EBS documentation.
gce
Google-based models have access to the ‘gce’ storage provider. The GCE provider does not currently have any specific configuration options.
kubernetes
See also: Persistent storage and Kubernetes
Kubernetes-based models have access to the ‘kubernetes’ storage provider, which supports the following pool attributes:
storage-class
The storage class for the Kubernetes cluster to use:
juju-unit-storage
juju-charm-storage
microk8s-hostpath
storage-provisioner
The Kubernetes storage provisioner. For example:
kubernetes.io/no-provisioner
kubernetes.io/aws-ebs
kubernetes.io/gce-pd
parameters.type
Extra parameters. For example:
gp2
pd-standard
lxd
The regular package archives for Ubuntu 14.04 LTS (Trusty) and Ubuntu 16.04 LTS (Xenial) do not include a version of LXD that has the ‘lxd’ storage provider feature. You will need at least version 2.16. See the Using LXD with Juju page for installation help.
LXD-based models have access to the ‘lxd’ storage provider. The LXD provider has two configuration options:
driver
- This is the LXD storage driver (e.g. zfs, btrfs, lvm, ceph).
lxd-pool
- The name to give to the corresponding storage pool in LXD.
Any other parameters will be passed to LXD (e.g. zfs.pool_name). See upstream LXD storage configuration for LXD storage parameters.
Every LXD-based model comes with a minimum of one LXD-specific Juju storage pool called ‘lxd’. If ZFS and/or BTRFS are present when the controller is created then pools ‘lxd-zfs’ and/or ‘lxd-btrfs’ will also be available. The following output to the juju storage-pools
command shows all three Juju LXD-specific pools:
Name Provider Attributes
loop loop
lxd lxd
lxd-btrfs lxd driver=btrfs lxd-pool=juju-btrfs
lxd-zfs lxd driver=zfs lxd-pool=juju-zfs zfs.pool_name=juju-lxd
rootfs rootfs
tmpfs tmpfs
As can be inferred from the above output, for each Juju storage pool based on the ‘lxd’ storage provider there is a LXD storage pool that gets created. It is these LXD pools that will house the actual volumes.
The LXD pool corresponding to the Juju ‘lxd’ pool doesn’t get created until the latter is used for the first time (typically via the juju deploy
command). It is called simply ‘juju’.
The command lxc storage list
is used to list LXD storage pools. A full “contingent” of LXD non-custom storage pools would like like this:
| NAME | DESCRIPTION | DRIVER | SOURCE | USED BY |
| default | | dir | /var/lib/lxd/storage-pools/default | 1 |
| juju | | dir | /var/lib/lxd/storage-pools/juju | 0 |
| juju-btrfs | | btrfs | /var/lib/lxd/disks/juju-btrfs.img | 0 |
| juju-zfs | | zfs | /var/lib/lxd/disks/juju-zfs.img | 0 |
The three Juju-related pools above are for storing volumes that Juju applications can use. The fourth ‘default’ pool is the standard LXD storage pool where the actual containers (operating systems) live.
To deploy an application, refer to the pool as usual. Here we deploy PostgreSQL using the ‘lxd’ Juju storage pool, which, in turn, uses the ‘juju’ LXD storage pool:
juju deploy postgresql --storage pgdata=lxd,8G
See Using LXD with Juju for how to use LXD in conjunction with Juju, including the use of ZFS as an alternative filesystem.
LXD (localhost) does not officially support attaching loopback devices for storage out of the box. However, with some configuration you can make this work.
Each container uses the ‘default’ LXD profile, but also uses a model-specific profile with the name juju-<model-name>
. Editing a profile will affect all of the containers using it, so you can add loop devices to all LXD containers by editing the ‘default’ profile, or you can scope it to a model.
To add loop devices to your container, add entries to the ‘default’, or model-specific, profile, with lxc profile edit <profile>
devices:
loop-control:
major: "10"
minor: "237"
path: /dev/loop-control
type: unix-char
loop0:
major: "7"
minor: "0"
path: /dev/loop0
type: unix-block
loop1:
major: "7"
minor: "1"
path: /dev/loop1
type: unix-block
loop9:
major: "7"
minor: "9"
path: /dev/loop9
type: unix-block
Doing so will expose the loop devices so the container can acquire them via the losetup
command. However, it is not sufficient to enable the container to mount filesystems onto the loop devices. One way to achieve that is to make the container “privileged” by adding:
config:
security.privileged: "true"
maas
MAAS has support for discovering information about machine disks, and an API for acquiring nodes with specified disk parameters. Juju’s MAAS provider has an integrated ‘maas’ storage provider. This storage provider is static-only; it is only possible to deploy charmed operators using ‘maas’ storage to a new machine in MAAS, and not to an existing machine, as described in the section on dynamic storage.
The MAAS provider currently has a single configuration attribute:
tags
- A comma-separated list of tags to match on the disks in MAAS. For example, you might tag some disks as ‘fast’; you can then create a storage pool in Juju that will draw from the disks with those tags.
oracle
Oracle-based models have access to the ‘oracle’ storage provider. The Oracle provider currently supports a single pool configuration attribute:
volume-type
Volume type, a value of ‘default’ or ‘latency’. Use ‘latency’ for low-latency, high IOPS requirements, and ‘default’ otherwise.
For convenience, the Oracle provider registers two predefined pools:
- ‘oracle’ (volume type is ‘default’)
- ‘oracle-latency’ (volume type is ‘latency’).
