Storage pool
Storage > Storage pool
See also: How to manage storage pools
A storage pool is defined on top of a storage provider.
A storage pool is a mechanism for administrators to define sources of storage that they will use to satisfy application storage requirements.
A single pool might be used for storage from units of many different applications - it is a resource from which different stores may be drawn.
A pool describes provider-specific parameters for creating storage, such as performance (e.g. IOPS), media type (e.g. magnetic vs. SSD), or durability.
For many providers, there will be a shared resource where storage can be requested (e.g. for Amazon EC2, ebs). Creating pools there maps provider specific settings into named resources that can be used during deployment.
Pools defined at the model level are easily reused across applications. Pool creation requires a pool name, the provider type and attributes for configuration as space-separated pairs, e.g. tags, size, path, etc.
For Kubernetes models, the provider type defaults to “kubernetes” unless otherwise specified.
