From zero to hero: Write your first Kubernetes charm > Set up your development environment
See previous: Study your application
In this chapter of the tutorial you will set up your development environment.
Contents:
- Create your charm project directory
- Set up an Ubuntu VM with Multipass
- Install Charmcraft
- Get Ops
- Install MicroK8s
- Set up Juju
- Install Tox
On your local machine, create your charm project directory. On Linux, for example, run:
mkdir ~/fastapi-demo
In your home directory, this will create a directory called fastapi-demo
. It is the directory where you will put all your charm files.
The goal of this section is to help you get a Linux machine that supports installation from snap, so that you can install Charmcraft.
If you already have that, we still recommend this step as a way for you to experiment in an isolated development environment.
If you however wish to continue directly on your existing Linux machine, you may do so â just ignore the code lines where we go through Multipass.
However, please keep in mind that the instructions in this tutorial have only been tested for the scenario with Multipass.
First, on your local machine, install Multipass: Linux | macOS | Windows.
Multipass is a tool that will help you quickly spin up an Ubuntu VM.
Read more: Multipass
Now, open a terminal window and use Multipass to launch an Ubuntu VM called charm-dev
# Launch a VM "charm-dev" with 8 GB RAM, 2 CPU cores, and 20 GB disk:
multipass launch -n charm-dev -m 8g -c 2 -d 20G
# >>> Launched: charm-dev
As a crucial piece of the SDK â Charmcraft â requires a Linux machine that supports installation via snap, this step ensures you will have a suitable machine. As development can be messy, this also ensures that you can quickly bounce back in case anything goes wrong.
Read more:
multipass launch
,multipass delete
Now use Multipass to mount your local project directory to your VM, as below.
# Mount a project dir, see https://multipass.run/docs/mount-command
multipass mount ~/fastapi-demo charm-dev:~/fastapi-demo
With this setup you can use your preferred editor to make changes on your local machine, and all these changes will be available inside the VM as well, at the mount point ~/fastapi-demo
Read more:
multipass mount
Finally, open a shell inside the VM:
multipass shell charm-dev
# >>> ubuntu@charm-dev:~$
Any command you type after the last terminal prompt (ubuntu@charm-dev:~$
) will be inside of this VM.
Read more:
multipass shell
Install Charmcraft
On your Ubuntu VM, install the SDKâs CLI tool Charmcraft:
# Charmcraft relies on LXD. Configure LXD:
lxd init --auto
# Install Charmcraft:
sudo snap install charmcraft --classic
Charmcraft will give you access to a rich set of powerful CLI commands. You can use them to simplify the creation, building, and publication of your charm.
Read more: Charmcraft (
charmcraft
Get Ops
The next thing youâll need is the SDKâs Python operator framework Ops. You donât need to do anything to get it at this point â just plan on using it. That is, be ready to require, use, and import it in your code as you would any other Python library.
Read more: Ops (
ops
Install MicroK8s
On your Ubuntu VM, install and configure MicroK8s:
If youâre not using a Multipass VM but rather your existing Linux:
In the instructions below, replace the ubuntu
user with $USER
# Install Microk8s from snap:
sudo snap install microk8s --channel 1.25-strict/stable
# Add the 'ubuntu' user to the MicroK8s group:
sudo usermod -a -G snap_microk8s ubuntu
# Give the 'ubuntu' user permissions to read the ~/.kube directory:
sudo chown -f -R ubuntu ~/.kube
# Create the 'microk8s' group:
newgrp snap_microk8s
# Enable the necessary MicroK8s addons:
sudo microk8s enable hostpath-storage dns
# Set up a short alias for the Kubernetes CLI:
sudo snap alias microk8s.kubectl kubectl
MicroK8s is a minimal production Kubernetes, so now you have a small Kubernetes cloud (by default called microk8s
) on your machine.
Read more: MicroK8s
Set up Juju
On your Ubuntu VM, install Juju, connect it to your MicroK8s cloud, and prepare a workspace (âmodelâ):
# Install 'juju':
sudo snap install juju --channel 3.1/stable
# >>> juju (3.1/stable) 3.1.2 from Canonicalâ installed
# Since the juju package is strictly confined, you also need to manually create a path:
mkdir -p ~/.local/share
# Register your "microk8s" cloud with juju:
# Not necessary --juju recognises a MicroK8s cloud automatically, as you can see by running 'juju clouds'.
juju clouds
# >>> Cloud Regions Default Type Credentials Source Description
# >>> localhost 1 localhost lxd 0 built-in LXD Container Hypervisor
# >>> microk8s 1 localhost k8s 1 built-in A Kubernetes Cluster
# (If for any reason this doesn't happen, you can register it manually using 'juju add-k8s microk8s'.)
# Install a "juju" controller into your "microk8s" cloud.
# We'll name ours "tutorial-controller".
juju bootstrap microk8s tutorial-controller
# Create a workspace, or 'model', on this controller.
# We'll call ours "charm-model".
# Juju will create a Kubernetes namespace "charm-model"
juju add-model charm-model
# Check status:
juju status
# >>> Model Controller Cloud/Region Version SLA Timestamp
# >>> charm-model tutorial-controller microk8s/localhost 3.0.2 unsupported 16:05:03+01:00
# >>> Model "admin/charm-model" is empty.
# There's your charm model!
# This is where you will deploy your charm.
If youâre building a charm youâve probably already used Juju, and you already know what all this is about â this model on MicroK8s is where you will use Juju to test-deploy and test-operate your charm, to make sure that it will work for anyone else wanting to use your charm as well.
Read more: Juju
Install Tox
On your Ubuntu VM, install Tox:
# tox depends on Python and pip
sudo apt install python3
# Get tox via pip
python -m pip install --user tox
As you probably already know if youâve worked in Python, Tox is a tool to automate environment setup for automated and standardized testing. You will use it in a bit to check that the charm youâve built actually works as intended.
Read more: Tox
Congratulations, your development environment is now ready!
Now, if you want to:
Continue the tutorial:
- Use the project directory on your host machine to create and edit your charm files.
- Use your Ubuntu VM to run Charmcraft or Juju commands.
- To pause:
Stop the Ubuntu VM by runningmultipass stop charm-dev
. - To resume:
Restart the Ubuntu VM:multipass start charm-dev
Reopen a shell into it:multipass shell charm-dev
Reaccess the charm project directory:cd ~/fastapi-demo
Abandon the tutorial and clean up:
- Delete the Ubuntu VM:
multipass delete --purge charm-dev
- Delete the charm project directory from your host machine.
See next: Create a minimal Kubernetes charm
