| Key | Value |
| Summary | Learn an approach to setting up remote access to your Charmed Kubeflow deployment |
| Categories | docs, kubeflow |
| Difficulty | 3 |
| Author | Rob Gibbon |
Overview
Duration: 2:00
Charmed Kubeflow delivers a powerful, sophisticated end-to-end MLOps platform which you can deploy in half an hour or less, using MicroK8s or another conformant Kubernetes distribution.
Exposing Charmed Kubeflow over the network so that users can access it is straightforward when you know how, and this tutorial will guide you through the steps needed to get things deployed and configured right for your users.
What youāll learn
- How to configure MicroK8s to expose Charmed Kubeflow to the outside world
- How to configure your Charmed Kubeflow for round-robin DNS to simplify accessing the platform, with Dnsmasq and Systemd-Resolved
What youāll need
- A MicroK8s cluster running on Ubuntu 20.04 with one or more nodes running Charmed Kubeflow and
MetalLB- see the install guide to get up and running - Another computer running a modern web browser from which to test remote access to Charmed Kubeflow
- Some command line knowledge
Enable MicroK8s ingress addon
Duration: 3:00
The first step we need to complete will be to enable an ingress on our MicroK8s cluster. On one of the MicroK8s nodes, run the following command:
microk8s enable ingress
Next, weāll configure the ingress add-on so that it exposes our Charmed Kubeflow MLOps platform. Just make sure that youāve followed the steps in the install guide and have MetalLB enabled on MicroK8s for your cluster first. Run the following commands to expose your Charmed Kubeflow deployment for remote access:
cat << EOF > ingress.yaml
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/rewrite-target: /
spec:
ingressClassName: public
rules:
- host: kubeflow.ubuntu.local
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
EOF
microk8s.kubectl apply -f ingress.yaml -nkubeflow
That wasnāt so bad! Wait a few moments until MicroK8s makes the configuration change:
microk8s.kubectl get ingress -nkubeflow
NAME CLASS HOSTS ADDRESS PORTS AGE
kubeflow-ingress public kubeflow.ubuntu.local 127.0.0.1 80 29s
Now weāll make remote access for your clients highly available with round-robin DNS so that if any node of the MicroK8s cluster goes offline, your users will still be able to reach Charmed Kubeflow. Read onā¦
Setting up dnsmasq
Duration: 10:00
The next step is to set up Dnsmasq on two of the MicroK8s nodes. We are going to use Dnsmasq as a lightweight caching DNS service that also resolves all of our local MicroK8s hosts to the domain name kubeflow.ubuntu.local, in order to set up round-robin DNS.
ā Round-robin DNS Round-robin DNS is a way to ensure improved service availability and load-balancing via DNS, by load-balancing requests across multiple DNS records with the same āAā record but different IP addresses.
First letās install the Dnsmasq package. Again, on each node in the MicroK8s cluster, run the following command:
sudo apt install dnsmasq -y
Next we need to configure the Dnsmasq daemon. We want Dnsmasq to listen for DNS lookup requests on our MicroK8s nodesā loopback interface as well as on the public interface. Note that your server may have more than one network interface - make sure you choose the right one!
You can find a lot of information about your MicroK8s nodeās network configuration by running the following command:
ip addr
Ok, letās go ahead and configure Dnsmasq. Note that you should replace the IP address assigned to the variable PUBLIC_IP with your own MicroK8s cluster nodeās public IP address, which will likely be different to the one shown below.
Run these commands on each MicroK8s cluster node to set up Dnsmasq as a caching DNS server that recursively forwards unknown lookups to Googleās public DNS:
PUBLIC_IP=192.168.100.10
cat << EOF > dnsmasq.local.conf
domain-needed
bogus-priv
no-poll
server=8.8.8.8
server=8.8.4.4
listen-address=$PUBLIC_IP
except-interface=l0
bind-interfaces
EOF
cat dnsmasq.local.conf | sudo tee -a /etc/dnsmasq.d/local.conf
The next step is to set up static records for Dnsmasq on each of the nodes where Dnsmasq is running. We want to create a static record for each node in the MicroK8s cluster. On each node in the MicroK8s cluster, run the following commands:
declare -a microk8s_cluster=("192.168.100.10" "192.168.100.11" "192.168.100.12")
for node in ${microk8s_cluster[@]}; do
echo "$node kubeflow.ubuntu.local" | sudo tee -a /etc/hosts
done
Alright, we want to bounce Dnsmasq so that it picks up our configuration changes.
sudo systemctl enable dnsmasq
sudo systemctl restart dnsmasq
But there are some extra steps here, to ensure that our servers and clients using systemd-resolved can make use of Dnsmasq. On each node of the cluster, and the systems that will access it, run the following commands:
echo "DNS=192.168.100.10" | sudo tee -a /etc/systemd/resolved.conf
echo "FallbackDNS=192.168.100.11" | sudo tee -a /etc/systemd/resolved.conf
sudo systemctl restart systemd-resolved
sudo systemd-resolve --flush-caches
Configure CoreDNS for Dnsmasq
Duration: 3:00
In order for internal services like the authentication system OIDC-gatekeeper to be able to resolve our Charmed Kubeflow serviceās hostname correctly, we need to configure CoreDNS to recursively lookup external addresses via Dnsmasq. Letās do that now:
microk8s disable dns
microk8s enable dns:192.168.100.10,192.168.100.11
Reconfigure the Charmed Kubeflow public URL
Duration: 4:00
The final step is to reconfigure the Charmed Kubeflow public URL so that the OIDC Gatekeeper and Dex operators know how users will access Charmed Kubeflow. On the computer running Juju, execute the following two commands to complete the setup:
juju config oidc-gatekeeper public-url=http://kubeflow.ubuntu.local
juju config dex-auth public-url=http://kubeflow.ubuntu.local
Next Steps
Duration: 1:00
Congratulations on setting up highly available remote access to your Charmed Kubeflow MLOps platform running on MicroK8s! But if youāre having difficulties, donāt worry - head over to the forum to ask a question and get in touch with the community.
Further reading
Duration: 1:00
- Read the Charmed Kubeflow authentication guide
- How to use Charmed Kubeflow with GPUs
Have questions? Contact our sales team now.
