Self Signed X.509 Certificates tutorial
The Self Signed X.509 Certificates Operator provides self-signed X.509 certificates to your charms by setting up a relation with a requirer charm. This charm generates a self-signed X.509 certificates for a requirer by using Certificate Signing Request sent in the relation databag.
This charm is useful when developing charms or when deploying charms in non-production environment.In this tutorial we will walk through how to:
- Set up an environment using Multipass with MicroK8s and Juju.
- Deploy Self Signed X.509 Certificates Operator using a single command.
- Configuring charm
- Setting up relations with other charms
- Getting signed certificates
- Managing application and units
Make Self Signed Certificates Operator up and running
To deploy Self Signed X.509 Certificates Operator, all you need to do is run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy self-signed-certificates --channel edge
Juju will now fetch self-signed-certificates operator and begin deploying it to the local MicroK8s. This process can take several minutes depending on how provisioned (RAM, CPU, etc) your machine is. You can track the progress by running:
juju status --watch 1s
This command is useful for checking the status of self-signed-certificates operator. Some of the helpful information it displays include IP addresses, ports, state, etc. The command updates the status of Self Signed Certificates Operator every second and as the application starts you can watch the status and messages of operator change. Wait until the application is ready - when it is ready, juju status will show:
tutorial microk8s-localhost microk8s/localhost 3.1.5 unsupported 01:14:09+03:00
self-signed-certificates active 1 self-signed-certificates edge 17 10.152.183.40 no
self-signed-certificates/0* active idle 10.1.146.12
To exit the screen with juju status --watch 1s, enter Ctrl+c.
If you want to further inspect juju logs, can watch for logs with juju debug-log.
More info on logging at juju logs.
How to manage units
If Self Signed Certificates Operator is deployed with its default configuration, single unit exists. The Self Signed Certificates Operator works with single replica for the moment and scale up operation is not supported yet.
Scaling-down operation is performed using following command:
juju scale-application self-signed-certificates 0
Relating with other applications
This charm provides tls-certificates interface. To use the self-signed-certificates operator and provide certificates to another charm, the other charm needs to require the tls-certificates interface.
juju relate self-signed-certificates <your charm which needs tls certificates>
The relation status is shown by running following command:
juju status --relations
If the relation is established, the following output is expected:
Relation provider Requirer Interface Type
self-signed-certificates:certificates amf:certificates tls-certificates regular
Step-by-step guide
Here’s an overview of the steps required with links to our separate tutorials that deal with each individual step:
- Deploy Self Signed Certificates Operator
- Configure Self Signed Certificates Operator
- Managing your units
- Relate Self Signed Certificates Operator with other applications
- Get Signed Certificates
License:
The Self Signed X.509 Certificates Operator is distributed under the Apache Software License, version 2.0.
