Make Self Signed Certificates Operator up and running
This is part of the Self Signed X.509 Certificates Operator Tutorial. Please refer to this page for more information and the overview of the content.
Deploy
To deploy Self Signed X.509 Certificates Operator, all you need to do is run the following command, which will fetch the charm from Charmhub and deploy it to your model:
juju deploy self-signed-certificates --channel edge
Juju will now fetch self-signed-certificates operator and begin deploying it to the local MicroK8s. This process can take several minutes depending on how provisioned (RAM, CPU, etc) your machine is. You can track the progress by running:
juju status --watch 1s
This command is useful for checking the status of self-signed-certificates operator. Some of the helpful information it displays include IP addresses, ports, state, etc. The command updates the status of Self Signed Certificates Operator every second and as the application starts you can watch the status and messages of operator change. Wait until the application is ready - when it is ready, juju status
will show:
tutorial microk8s-localhost microk8s/localhost 3.1.5 unsupported 01:14:09+03:00
self-signed-certificates active 1 self-signed-certificates edge 17 10.152.183.40 no
self-signed-certificates/0* active idle 10.1.146.12
To exit the screen with juju status --watch 1s
, enter Ctrl+c
If you want to further inspect juju logs, can watch for logs with juju debug-log
More info on logging at juju logs.
