The Parca Scrape Agent Operator is a workloadless charm meant to act as integration point for uncharmed workloads exposing a pprof endpoint so that they can be scraped by the parca-k8s charm.
This charm is in that respect very similar to prometheus-scrape-target.
PR for code review: parca-scrape-target-operator/pull/428
Metadata links
- charmhub.io : Charmhub | Deploy Parca Scrape Target Operator using Charmhub - The Open Operator Collection
- project repository: GitHub - canonical/parca-scrape-target-operator: A charmed operator for scraping Parca targets that do not exist within the Juju model. · GitHub
CI Links
- Code linting or-style checks: parca-scrape-target-operator/tox.ini at main · canonical/parca-scrape-target-operator · GitHub
- Release automation: observability/.github/workflows/charm-pull-request.yaml at main · canonical/observability · GitHub
- Unit test implementation: parca-k8s-operator/tests/unit at main · canonical/parca-scrape-target-operator · GitHub
- Unit test results: https://github.com/canonical/parca-scrape-target-operator/actions/runs/13493720782
- Integration test implementation:parca-scrape-target-operator/tests/integration at main · canonical/parca-scrape-target-operator · GitHub
- Integration test results: https://github.com/canonical/parca-scrape-target-operator/actions/runs/13493720782
Documentation Links
- Usage: Charmed Parca
- Contribution: parca-scrape-target-operator/CONTRIBUTING.md at main · canonical/parca-scrape-target-operator · GitHub
- Licensing: parca-scrape-target-operator/LICENSE at main · canonical/parca-scrape-target-operator · GitHub
- Publisher: Pietro Pasotti (pietro.pasotti@canonical.com) Canonical Observabitaly platform
