python-libjuju (Juju client)
When Juju 4.0 is released, if you upgrade your juju client to 4+: That will introduce a change that will break the python-libjuju client. This issue will be addressed in an upcoming python-libjuju release. Stay tuned and make sure to update! See more: Discourse | Juju 4.0 AllWatcher API changes.
python-libjuju is one of the client libraries of Juju that allows interaction with a Juju controller via Python scripts.
Install it on your Python setup (e.g. pip install juju), and you have the full control of your infrastructure that you can control via your scripts. python-libjuju often proves to be very useful in automated testing, as well as quick interactions with Juju entities using just the Python repl.
Source: GitHub | python-libjuju
Example uses: GitHub | python-libjuju/examples
Reference docs: Read the docs | python-libjuju
Project: PyPi Project | Juju
Contributors: @cderici, @simonrichardson , @tmihoc
