Cross-version compatibility in Juju
Commonly, you may have to work with multiple versions of Juju at once. This document describes the compatibility rules between different versions of Juju.
juju CLI client, controllers and agents
Juju controllers, agents, and the juju CLI client all are semantically versioned. This means:
  • Controllers/agents/clients in the same major/minor series (e.g. 3.5.0 and 3.5.2) are fully compatible.
  • Controllers/agents/clients in the same major series (e.g. 3.4 and 3.5) are compatible, but older versions may be lacking features present in newer versions.
  • Controllers/agents/clients with different major versions (e.g. 2.8 and 3.1) are not guaranteed to be compatible. The one exception is that we guarantee a basic set of operations (e.g. status and migration) is compatible between the last minor in a major series and the next major. This enables users to upgrade their existing deployments to the next major version. Related to that: A Juju client only bootstraps a Juju controller of the same major/minor version.
python-libjuju
  • For a 2.9.x controller, you should use the latest python-libjuju in the 2.9 track.
  • For 3.x controllers, you should use the latest version of python-libjuju.
Terraform Juju provider
The latest version of the Terraform Juju provider should be compatible with all Juju controllers.
