Preserve your charm's data
From Zero to Hero: Write your first Kubernetes charm > Preserve your charm’s data
See previous: Integrate your charm with PostgreSQL
This document is part of a series, and we recommend you follow it in sequence. However, you can also jump straight in by checking out the code from the previous branches:
git clone https://github.com/canonical/juju-sdk-tutorial-k8s.git
cd juju-sdk-tutorial-k8s
git checkout 04_integrate_with_psql
git checkout -b  05_preserve_charm_data
Charms are stateless applications. That is, they are reinitialised for every event and do not retain information from previous executions. This means that, if an accident occurs and the Kubernetes pod dies, you will also lose any information you may have collected.
In many cases that is not a problem. However, there are situations where it may be necessary to maintain information from previous runs and to retain the state of the application. As a charm author you should thus know how to preserve state.
There are a few strategies you can adopt here:
First, you can use an Ops construct called Stored State. With this strategy you can store data on the local unit (at least, so long as your main function doesn’t set use_juju_for_storage to True). However, if your Kubernetes pod dies, your unit also dies, and thus also the data. For this reason this strategy is generally not recommended.
Read more: StoredState, StoredState: Uses, Limitations
Second, you can make use of the Juju notion of ‘peer relations’ and ‘data bags’ and set up a peer relation data bag. This will help you store the information in the Juju’s database backend.
Read more: Integration data
Third, when you have confidential data, you can use Juju secrets (from Juju 3.1 onwards).
Read more: Juju OLM | Secret
In this chapter we will adopt the second strategy, that is, we will store charm data in a peer relation databag. (We will explore the third strategy in a different scenario in the next chapter.) We will illustrate this strategy with an artificial example where we save the counter of how many times the application pod has been restarted.
Contents:
  1. Define a peer relation
  2. Set and get data from the peer relation databag
  3. Validate your charm
  4. Review the final code
The first thing you need to do is define a peer relation. Update the charmcraft.yaml file to add a peers block before the requires block, as below (where fastapi-peer is a custom name for the peer relation and fastapi_demo_peers is a custom name for the peer relation interface):
peers:
  fastapi-peer:
    interface: fastapi_demo_peers
Read more: File ‘charmcraft.yaml’
Now, you need a way to set and get data from the peer relation databag. For that you need to update the src/charm.py file as follows:
First, define some helper methods that will allow you to read and write from the peer relation databag:
@property
def peers(self):
    """Fetch the peer relation."""
    return self.model.get_relation(PEER_NAME)
def set_peer_data(self, key: str, data: Any) -> None:
    """Put information into the peer data bucket instead of `StoredState`."""
    self.peers.data[self.app][key] = json.dumps(data)
def get_peer_data(self, key: str) -> dict[Any, Any]:
    """Retrieve information from the peer data bucket instead of `StoredState`."""
    if not self.peers:
        return {}
    data = self.peers.data[self.app].get(key, "")
    return json.loads(data) if data else {}
This block uses the built-in json module of Python, so you need to import that as well. You also need to define a global variable called PEER_NAME = "fastapi-peer", to match the name of the peer relation defined in charmcraft.yaml file. At the beginning of your file, right after the import section, add all of the following:
import json
from typing import Any
Next, you need to add a method that updates a counter for the number of times a Kubernetes pod has been started. Let’s make it retrieve the current count of pod starts from the ‘unit_stats’ peer relation data, increment the count, and then update the ‘unit_stats’ data with the new count, as below:
def _count(self, event) -> None:
    unit_stats = self.get_peer_data("unit_stats")
    counter = unit_stats.get("started_counter", 0)
    self.set_peer_data("unit_stats", {"started_counter": int(counter) + 1})
Finally, you need to call this method and update the peer relation data every time the pod is started. For that, define another event observer in the __init__ method, as below:
framework.observe(self.on.start, self._count)
Validate your charm
First, repack and refresh your charm:
charmcraft pack
juju refresh \
  --path="./demo-api-charm_ubuntu-22.04-amd64.charm" \
  demo-api-charm --force-units --resource \
  demo-server-image=ghcr.io/canonical/api_demo_server:1.0.0
Next, run juju status to make sure the application is refreshed and started, then investigate the relation data as below:
juju show-unit demo-api-charm/0
The output should include the following lines related to our peer relation:
  relation-info:
  - relation-id: 25
    endpoint: fastapi-peer
    related-endpoint: fastapi-peer
    application-data:
      unit_stats: '{"started_counter": 1}'
Now, simulate a Kubernetes pod crash by deleting the charm pod:
microk8s kubectl --namespace=charm-model delete pod demo-api-charm-0
Finally, check the peer relation again. You should see that the started_counter has been incremented by one. Good job, you’ve preserved your application data across restarts!
For the full code see: 05_preserve_charm_data
For a comparative view of the code before and after this doc see: Comparison
See next: Expose your charm’s operational tasks via actions
Contributors: @beliaev-maksim, @mylesjp, @tony-meyer, @tmihoc
There are a few references to metadata.yaml in this document that should be changed to charmcraft.yaml with the latest changes in Charmcraft 2.5.
The first thing you need to do is define a peer relation. Update the metadata.yaml file to add a peers block before the requires block, as below (where fastapi-peer is a custom name for the peer relation and fastapi_demo_peers is a custom name for the peer relation interface):
peers:
  fastapi-peer:
Read more: File ‘metadata.yaml’
This block uses the built-in json module of Python, so you need to import that as well. You also need to define a global variable called PEER_NAME = "fastapi-peer", to match the name of the peer relation defined in metadata.yaml file. At the beginning of your file, right after the import section, add all of the following:
