This is part of the PgBouncer Tutorial
Enable TLS
Transport Layer Security (TLS)
Transport Layer Security (TLS) is a protocol used to encrypt data exchanged between two applications. Essentially, it secures data transmitted over a network.
Typically, enabling TLS internally within a highly available database or between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. This has all been encoded into Charmed PgBouncer. This means (re-)configuring TLS on this charm is readily available and requires minimal effort on your end.
Again, integrations come in handy here, as TLS is enabled by relating Charmed PostgreSQL to the Self Signed Certificates Charm. This charm centralises TLS certificate management consistently and handles operations like providing, requesting, and renewing TLS certificates.
In this section, we will learn how to set up the pgbouncer, data-integrator, postgresql, and self-signed-certificates charms to enable TLS encryption.
Disclaimer: In this tutorial, we use self-signed certificates provided by the self-signed-certificates-operator.
This is not recommended for a production environment.
For production environments, check the collection of Charmhub operators that implement the tls-certificate interface, and choose the most suitable for your use-case.
Configure TLS
Before enabling TLS on Charmed PostgreSQL VM, we must deploy the self-signed-certificates charm:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait until the self-signed-certificates is up and active, using juju status --watch 1s to monitor the progress:
tutorial overlord localhost/localhost 3.1.7 unsupported 13:56:00+01:00
data-integrator active 1 data-integrator stable 19 no
pgbouncer 1.21.0 active 1 pgbouncer 1/stable 88 no
postgresql 14.10 active 2 postgresql 14/stable 363 no
self-signed-certificates active 1 self-signed-certificates stable 72 no
data-integrator/0* active idle 4 10.89.24.109
pgbouncer/0* active idle 10.89.24.109
postgresql/0* active idle 0 10.89.24.187 5432/tcp Primary
postgresql/1 active idle 1 10.89.24.149 5432/tcp
self-signed-certificates/0* active idle 3 10.89.24.189
0 started 10.89.24.187 juju-151b7f-0 ubuntu@22.04 Running
1 started 10.89.24.149 juju-151b7f-1 ubuntu@22.04 Running
3 started 10.89.24.189 juju-151b7f-3 ubuntu@22.04 Running
4 started 10.89.24.109 juju-151b7f-4 ubuntu@22.04 Running
Add external TLS certificate
Since we are using the external application data-integrator, PgBouncer will open a port to listen to TCP traffic. In this case, because PgBouncer is exposed, it is recommended to enable TLS encryption.
Enable TLS for PgBouncer by integrating it with self-signed-certificates:
juju integrate pgbouncer self-signed-certificates
Enable TLS the same way for PostgreSQL:
juju integrate postgresql self-signed-certificates
Congratulations! Your connections between data-integrator and PgBouncer and between PgBouncer and PostgreSQL is now using TLS certificate generated by the external application self-signed-certificates.
Remove external TLS certificate
To remove the TLS certificates, simply remove the integrations:
juju remove-relation pgbouncer self-signed-certificates
juju remove-relation postgresql self-signed-certificates
