Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your PgBouncer application.
To summarize:
- Deploy the Tempo charm in a COS K8s environment
- Integrate it with the COS charms
- Offer interfaces for cross-model integrations
- View PgBouncer traces on Grafana
This feature is available for Charmed PgBouncer revision 210+ only.
- Have deployed a Charmed PostgreSQL application
- Have deployed a Charmed PgBouncer application in the same model as the Charmed PostgreSQL application
- Have deployed a ‘cos-lite’ bundle from the
latest/edgetrack in a Kubernetes environment
Deploy Tempo
Then, deploy the tempo-k8s charm:
juju deploy -n 1 tempo-k8s --channel latest/edge
Integrate with the COS charms
Integrate tempo-k8s with the COS charms as follows:
juju integrate tempo-k8s:grafana-dashboard grafana:grafana-dashboard
juju integrate tempo-k8s:grafana-source grafana:grafana-source
juju integrate tempo-k8s:ingress traefik:traefik-route
juju integrate tempo-k8s:metrics-endpoint prometheus:metrics-endpoint
juju integrate tempo-k8s:logging loki:logging
If you would like to instrument traces from the COS charms as well, create the following integrations:
juju integrate tempo-k8s:tracing alertmanager:tracing
juju integrate tempo-k8s:tracing catalogue:tracing
juju integrate tempo-k8s:tracing grafana:tracing
juju integrate tempo-k8s:tracing loki:tracing
juju integrate tempo-k8s:tracing prometheus:tracing
juju integrate tempo-k8s:tracing traefik:tracing
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed PgBouncer is deployed.
juju offer tempo-k8s:tracing
Then, switch to the Charmed PgBouncer model, find the offers, and integrate (relate) with them:
juju switch <machine_controller_name>:<pgbouncer_model_name>
Do not miss the “
:” in the command above.
Store URL Access Interfaces
k8s admin/cos.tempo-k8s admin tracing:tracing
juju consume k8s:admin/cos.tempo-k8s
Relate Charmed PgBouncer with the above consumed interface:
juju integrate pgbouncer:tracing tempo-k8s:tracing
Wait until the model settles. The following is an example of the juju status --relations on the Charmed PgBouncer model:
database lxd localhost/localhost 3.4.3 unsupported 18:19:57Z
SAAS Status Store URL
tempo-k8s active uk8s admin/cos.tempo-k8s
pgbouncer 1.21.0 active 1 pgbouncer 1/edge 290 no
postgresql 14.11 active 1 postgresql 14/edge 436 no
postgresql-test-app active 1 postgresql-test-app latest/edge 176 no received database credentials of the first database
postgresql-test-app/0* active idle 1 10.205.193.243 received database credentials of the first database
pgbouncer/0* active idle 10.205.193.243
postgresql/0* active idle 0 10.205.193.129 5432/tcp Primary
0 started 10.205.193.129 juju-6cd8c5-0 ubuntu@22.04 Running
1 started 10.205.193.243 juju-6cd8c5-1 ubuntu@22.04 Running
pgbouncer:database postgresql-test-app:first-database postgresql_client subordinate
pgbouncer:pgb-peers pgbouncer:pgb-peers pgb_peers peer
pgbouncer:upgrade pgbouncer:upgrade upgrade peer
postgresql-test-app:postgresql-test-peers postgresql-test-app:postgresql-test-peers postgresql-test-peers peer
postgresql:database pgbouncer:backend-database postgresql_client regular
postgresql:database-peers postgresql:database-peers postgresql_peers peer
postgresql:restart postgresql:restart rolling_op peer
postgresql:upgrade postgresql:upgrade upgrade peer
tempo-k8s:tracing pgbouncer:tracing tracing regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select pgbouncer as the Service Name under the Search tab to view traces belonging to Charmed PgBouncer.
Below is a screenshot demonstrating a Charmed PgBouncer trace:
Feel free to read through the Tempo documentation at your leisure to explore its deployment and its integrations
