How to access the PgBouncer admin console
This guide demonstrates how to access the PgBouncer admin console when integrated with PostgreSQL and the data-integrator charm.
Reveal the admin user credentials
Find the Juju secret ID:
$ SECRET_ID=$(juju secrets --format=json | jq -r 'to_entries[] | select(.value.label == "pgb-peers.pgbouncer.app") | .key')
If your PgBouncer app was deployed with a different name, make sure to modify the label to
"pgb-peers.<your-pgbouncer-name>.app"
Reveal the password:
$ juju show-secret --reveal $SECRET_ID --format=json | jq -r '.[].content.Data["admin-password"]'
Connect to the internal PgBouncer database
Connect using psql with the following URI format:
psql postgresql://pgbouncer_admin_<app_name>:<password>@<unit_ip>:<port>/pgbouncer
Note that The PgBouncer database will always be called pgbouncer and the admin username will follow the pattern of pgbouncer_admin_{pgbouncer app name}
Example:
$ juju status
admin-console localhost-localhost localhost/localhost 3.6.14 unsupported 14:41:41+02:00
data-integrator active 1 data-integrator latest/edge 368 no
pgbouncer active 1 pgbouncer 1/edge 900 no
postgresql 16.11 active 1 postgresql 16/edge 1031 no
data-integrator/0* active idle 1 10.7.41.82
pgbouncer/0* active idle 10.7.41.82 6432/tcp
postgresql/0* active idle 0 10.7.41.101 5432/tcp Primary
$ psql postgresql://pgbouncer_admin_pgbouncer:XHDgj1d3ZRn9egRWoCS9QH7N@10.7.41.82:6432/pgbouncer
psql (18.2, server 1.21.0/bouncer)
WARNING: psql major version 18, server major version 1.21.
Some psql features might not work.
Type "help" for help.
pgbouncer=# show stats;
database | total_xact_count | total_query_count | total_received | total_sent | total_xact_time | total_
query_time | total_wait_time | avg_xact_count | avg_query_count | avg_recv | avg_sent | avg_xact_time | av
g_query_time | avg_wait_time
pgbouncer | 3 | 3 | 0 | 0 | 0 |
0 | 0 | 0 | 0 | 0 | 0 | 0 |
0 | 0
testdb1 | 0 | 0 | 0 | 419 | 0 |
0 | 64884 | 0 | 0 | 0 | 0 | 0 |
0 | 0
(2 rows)
