Interfaces/endpoints
PgBouncer supports modern ‘postgresql_client’ interface. Applications can easily connect PgBouncer using ‘data_interfaces’ library from ‘data-platform-libs’.
Modern postgresql_client interface (database endpoint):
Adding a relation is accomplished with juju relate (or juju integrate for Juju 3.x) via endpoint database. Read more about Juju relations (integrations). Example:
# Deploy Charmed PostgreSQL and PgBouncer clusters
juju deploy postgresql -n 3 --channel 14/stable
juju deploy pgbouncer -n 3 --channel 1/stable
# Deploy the relevant charms, e.g. postgresql-test-app
juju deploy postgresql-test-app
# Relate all applications
juju integrate postgresql pgbouncer
juju integrate pgbouncer postgresql-test-app:database
# Check established relation (using postgresql_client interface):
juju status --relations
# Example of the properly established relation:
# > Integration provider Requirer Interface Type Message
# > pgbouncer:database postgresql-test-app:database postgresql_client regular
# > postgresql:database pgbouncer:backend-database postgresql_client regular
See all the charm interfaces here.
