This tutorial shows how to set up a fully working OpenFGA server using our charm, MicroK8s and Juju
Set things up
Bootstrap a microk8s controller using juju 3.2 and create a new Juju model:
$ juju add-model openfga
Added 'openfga' model on microk8s/localhost with credential 'microk8s' for user 'admin'
Deploy the charm
Deploy the openfga charm:
$ juju deploy openfga-k8s --channel edge
Deploying "openfga-k8s" from local charm "openfga-k8s", revision 0 on ubuntu@22.04/stable
OpenFGA requires a way to persist data, in the case of our charm we enforce the usage of a postgreSQL database. We are going to be using the postgresql-k8s charm
$ juju deploy postgresql-k8s --channel 14/stable --trust
Located charm "postgresql-k8s" in charm-hub, revision 233
Deploying "postgresql-k8s" from charm-hub charm "postgresql-k8s", revision 233 in channel 14/stable on ubuntu@22.04/stable
Integrate with PostgreSQL
Once that is done (no need to wait for it to be ready) we can proceed in deploying openfga and integrate the 2 charms
$ juju integrate postgresql-k8s:database openfga-k8s
after some time we should be able to inspect that all has been successfully deployed and connected
$ juju status --relations
openfga microk8s-localhost microk8s/localhost 3.1.7 unsupported 15:59:57+02:00
openfga-k8s active 1 openfga-k8s 0 10.152.183.172 no
postgresql-k8s 14.11 active 1 postgresql-k8s 14/stable 233 10.152.183.177 no Primary
openfga-k8s/0* active idle 10.1.245.154
postgresql-k8s/0* active idle 10.1.245.156 Primary
openfga-k8s:peer openfga-k8s:peer openfga-peer peer
postgresql-k8s:database openfga-k8s:database postgresql_client regular
postgresql-k8s:database-peers postgresql-k8s:database-peers postgresql_peers peer
postgresql-k8s:restart postgresql-k8s:restart rolling_op peer
postgresql-k8s:upgrade postgresql-k8s:upgrade upgrade peer
Deployment checks
Once all is up we can verify that OpenFGA is up and running by creating a store using the APIs
First find the secret:
$ juju secrets
ID Owner Rotation Revision Last updated
co9vcjrmrojc77r2rd2g openfga-k8s never 1 20 minutes ago
co9vd83mrojc77r2rd30 postgresql-k8s never 1 19 minutes ago
co9vg4bmrojc77r2rd3g postgresql-k8s never 1 13 minutes ago
$ juju show-secret co9vcjrmrojc77r2rd2g --reveal
co9vcjrmrojc77r2rd2g:
revision: 1
owner: openfga-k8s
created: 2024-04-08T13:51:12Z
updated: 2024-04-08T13:51:12Z
content:
token: tMkhBA0drx2nfqIubs9vR9KSeC3oIen5jYesTEL_gjM
Then we can try to create a store using the HTTP API (via httpie):
$ http POST :8080/stores name=openfga-demo Authorization:" Bearer tMkhBA0drx2nfqIubs9vR9KSeC3oIen5jYesTEL_gjM"
HTTP/1.1 201 Created
Content-Length: 143
Content-Type: application/json
Date: Mon, 08 Apr 2024 14:06:26 GMT
Vary: Origin
X-Http-Code: 201
X-Request-Id: 1da6c68d-d3fe-4e01-b957-19da07cb5270
"created_at": "2024-04-08T14:06:26.848060Z",
"id": "01HTZ0G7GZ4QEKHV82TV59H6ES",
"name": "openfga-demo",
"updated_at": "2024-04-08T14:06:26.848060Z"
Grafana, Loki, and Prometheus
This OpenFGA operator integrates with Canonical Observability Stack (COS) bundle. It comes with a Grafana dashboard as well as Loki and Prometheus alert rules for basic common scenarios. To integrate with the COS bundle, after you deploy it, you can run:
$ juju integrate openfga:grafana-dashboard grafana:grafana-dashboard
$ juju integrate openfga:metrics-endpoint prometheus:metrics-endpoint
$ juju integrate loki:logging openfga:log-proxy
Scale
To scale the OpenFGA server we can exploit juju scale-application
$ juju scale-application openfga-k8s 5
openfga-k8s scaled to 5 units
In due time, we should be able to see that all the requested units have come up successfully
openfga microk8s-localhost microk8s/localhost 3.1.7 unsupported 16:37:36+02:00
openfga-k8s active 5 openfga-k8s 0 10.152.183.172 no
postgresql-k8s 14.11 active 1 postgresql-k8s 14/edge 233 10.152.183.177 no Primary
openfga-k8s/1 active idle 10.1.245.141
openfga-k8s/2 active idle 10.1.245.144
openfga-k8s/3 active idle 10.1.245.155
openfga-k8s/4 active idle 10.1.245.131
Tear things down
To tear things down, remove the entire openfga model in juju with
juju destroy-model openfga
