Our docs have moved to a new home! Canonical Identity documentation
Please update your bookmarks, and contact us if you have any questions.
OpenFGA is a Kubernetes charm for OpenFGA
A high-performance and flexible authorization/permission engine built for developers and inspired by Google Zanzibar.
OpenFGA is designed to make it easy for developers to model their application permissions and add and integrate fine-grained authorization into their applications. It allows in-memory data storage for quick development, as well as pluggable database modules.
The operator currently only supports PostgreSQL.
In this documentation
| Tutorial Get started - a hands-on introduction to Example Product for new users |
Project and community
OpenFGA is a member of the Ubuntu family. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
Navigation
| Level | Path | Navlink |
| 1 | tutorial | Tutorial |
| 1 | how-to | How-to guides |
| 2 | how-to-integrate-with-openfga | Integration |
| 1 | reference | Reference |
| 2 | reference-observability | Observability |
| 2 | actions | Actions |
| 2 | configurations | Configurations |
| 2 | integrations | Integrations |
| 2 | libraries | Libraries |
| 2 | resources | Resources |
| 1 | explanation | Explanation |
| 2 | explanation-security | OpenFGA Charm Security |
