Integrate with OpenFGA
If you are charming an application that supports using OpenFGA for authorization, you can integrate with the OpenFGA charm to automatically create a store that will persist even if the relation is gone.
Add an integration endpoint to metadata.yaml
The OpenFGA store information is communicated over relation data, where the OpenFGA charm is the provider and the application is the requirer. For consistency accross the ecosystem, it is encouraged to name the relation openfga.
Edit your charm’s metadata.yaml to add, under provides, the following:
requires:
# any other providers your charm supports
openfga:
interface: openfga
Fetch the openfga charm library
The OpenFGA charm will create a store per openfga relation, which is managed by the openfga library.
charmcraft fetch-lib charms.openfga_k8s.v1.openfga
The library offers a OpenFGARequires object, which provides sensible defaults and a simple API that you can use to connect with the OpenFGA server.
Use OpenFGARequires
To initialise the library:
class SomeCharm(CharmBase):
def __init__(self, *args):
self.openfga = OpenFGARequires(self, "test-openfga-store")
self.framework.observe(
self.openfga.on.openfga_store_created,
self._on_openfga_store_created,
def _on_openfga_store_created(self, event: OpenFGAStoreCreateEvent):
if not event.store_id:
return
info = self.openfga.get_store_info()
if not info:
return
logger.info("store id {}".format(info.store_id))
logger.info("token {}".format(info.token))
logger.info("grpc_api_url {}".format(info.grpc_api_url))
logger.info("http_api_url {}".format(info.http_api_url))
When this charm is related with OpenFGA with:
juju integrate openfga:openfga some-charm:openfga
The OpenFGA charm will create a new store with the name test-openfga-store and provide the store id, along with any information needed to connect to the server in the databag.
If the relation is removed:
juju remove-relation openfga:openfga some-charm:openfga
The store will not be removed and the same store will be provided if the same charm is related with openfga. To achieve this, the OpenFGA charm assumes that the store-name requested by the application is unique.
