MySQL Router K8s Tutorial - Overview
MySQL Router K8s tutorial
The MySQL Router K8s Operator delivers automated operations management from day 0 to day 2 on the MySQL Router Community Edition lightweight middleware that provides transparent routing between your application and back-end MySQL Servers. It is an open source, end-to-end, production-ready data platform component on top of Juju. As a first step this tutorial shows you how to get MySQL Router K8s up and running, but the tutorial does not stop there. Through this tutorial you will learn a variety of operations, everything from adding replicas to advanced operations such as enabling Transport Layer Security (TLS). In this tutorial we will walk through how to:
  • Set up an environment using Multipass with Microk8s and Juju.
  • Deploy MySQL Router K8s using a single command.
  • Configure TLS certificate in one command.
While this tutorial intends to guide and teach you as you deploy MySQL Router K8s, it will be most beneficial if you already have a familiarity with:
Step-by-step guide
Here’s an overview of the steps required with links to our separate tutorials that deal with each individual step:
